Engine Guard Install Problem
Old Sep 26, 2010 | 08:37 AM
Andrew Riggs's Avatar
Andrew Riggs
Stage II
Default Engine Guard Install Problem
Hey everybody,
I have a 2007 XL 1200L and I tried installing the engine guard yesterday. The problem is there is some heat sink device that the bottom part of the engine guard goes into the bottom part of the fins on the heat sink. Anyone experience this problem?
-Andrew
Old Sep 26, 2010 | 09:32 AM
cHarley's Avatar
cHarley
There was a "recall" on the 07 voltage regulator heatsink because it "stuck out" too far towards the front fender. Have you had the recall done?
Old Sep 26, 2010 | 09:35 AM
HarleyScuba's Avatar
HarleyScuba
Are you talking about the voltage regulator between the front down tubes? Not to be insulting, but are you sure the engine guard is for a rubber mount frame? If you don't have them, here are the instructions. They show the lower mounting point below the voltage reg.
http://www.harley-davidson.com/en_US...ts/-J02822.pdf
Old Sep 26, 2010 | 09:42 AM
Andrew Riggs
Stage II
I bought the bike used and I don't believe it has had the recall done to it yet now that I know about that. The voltage regulator on mine is much larger and sits much lower than the one in the install manual. I'm going to bring the bike by the harley shop today and see about getting the recall done.
Thanks for the reply guys.
traveler
Dyna Parts
Mar 10, 2013 01:28 PM
Falcon195
Jun 17, 2012 09:20 PM
sancho_panza
Jan 31, 2009 11:34 PM
denimnightster
Jan 6, 2009 08:27 PM
GrandpaSpike
Screamin Eagle CVO Models
Oct 9, 2007 04:36 PM
