Brake light lens
Old Nov 3, 2010 | 06:55 PM
Jenks01's Avatar
Jenks01
Default Brake light lens
Anyone know where I can find a thin or slim brake light lens? I remove my license plate holder and put a vertical mount but the brake lens still has the white top for a the light and I dont like it plus it sticks to far out for my liking. Any ideas would be welcome.
Thanks
Old Nov 3, 2010 | 07:07 PM
chevy94ss's Avatar
chevy94ss
I think you are referring to a "layback lense" and you should be able to find one at HD, JPcycles, Ebay as well as a bunch of other places on the net
Old Nov 3, 2010 | 08:26 PM
mreed's Avatar
mreed
The lay down lense is the slimmest you'll be able to use because of the bulb. And even then you need to make sure the bulb doesn't touch the lense. I see alot of them with a melted circle right in the middle.
Old Nov 3, 2010 | 11:53 PM
Gpsjr10's Avatar
Gpsjr10
You can always paint the inside of the clear part red, or get a tail light lense repair kit, the kit has pieces of colored plastic you can use that to replace the clear part of the lense. It is sold at Advance Auto Parts.
Old Nov 4, 2010 | 03:46 AM
Jenks01's Avatar
Jenks01
Yeah I thought about maybe painting it from the inside or something. I just figured someone has to make a replacement lens that does not have the clear on top for the plate light. I also thought about just completely replacing the tail light or even making my turn signals into turn/brake lights. Has anyone seen this done on the sportsters? I know of a few people that have done it on some metrics.
Old Nov 4, 2010 | 04:52 AM
Gpsjr10's Avatar
Gpsjr10
There are modules that can be added to convert your t/s into run/brake/turn. Available from J&P Cycles and such.
Old Nov 4, 2010 | 05:28 AM
mreed's Avatar
mreed
The module is a good idea but you'll have a big hole in your fender where the tail light was...much bigger than the holes left from removing the license plate brkt.
I bought a lay down tail light lense from J & P once and the clear part for the license plate was on the bottom instead of the top. I don't know why, but I'm sure they have more of those.
Old Nov 4, 2010 | 11:24 AM
Jenks01's Avatar
Jenks01
Thanks guys, I dug around on the kuryakyn website and found one that was a laydown without the clear for $50. Not to bad I guess, price of doing business.
Thanks again for all the help, alot of knowledgeable people on here and you guys are definitely a lot nicer than some of the other forums around, so please don't change.
Old Nov 4, 2010 | 01:52 PM
XL50#674's Avatar
XL50#674
Good luck with the Kuryakyn part, I don't think they can make a good product. They make nice looking stuff, but it just does not hold up.
Oct 2, 2019 12:57 PM
eddie31770
Milwaukee Eight (M8)
Feb 21, 2019 11:23 PM
Capt. Mike
Jan 17, 2010 03:10 PM
07bob
Mar 14, 2009 06:27 AM
saltlick
Mar 30, 2007 10:29 AM
