question needs an answer
Old Nov 15, 2010 | 08:11 PM
smithcstm's Avatar
smithcstm
3rd Gear
Default question needs an answer
Question, im buying to be exact a high flow forward facing exposed element air cleaner and was wondering does it require a fuel pak?????I already have V&H long shots and did not get a fuel pak for those and the bike runs like a champ... i just dont want to mess anything up???
Old Nov 15, 2010 | 08:19 PM
Aaron48's Avatar
Aaron48
It is recomended because you are going to adding a lot of air to the AF mix and it is gonna get real lean. A fuel pack is only gonna make the bike run better.
Old Nov 15, 2010 | 08:28 PM
smithcstm's Avatar
smithcstm
3rd Gear
Default hmmmm
what would happen if i didnt put one on????
Old Nov 15, 2010 | 08:32 PM
xFreebirdx's Avatar
xFreebirdx
You'll burn holes through your pistons.
Old Nov 15, 2010 | 08:37 PM
Aaron48's Avatar
Aaron48
A friend actually did this with a carbed model we ended up replacing both heads and pistons....save up and add more fuel with a Fuelpack.
Old Nov 15, 2010 | 08:39 PM
smithcstm's Avatar
smithcstm
3rd Gear
thanks
Old Nov 15, 2010 | 08:40 PM
smithcstm's Avatar
smithcstm
3rd Gear
oh before i go how much does a fuel pak run ??? ball park
Old Nov 15, 2010 | 09:00 PM
Aaron48's Avatar
Aaron48
At Dennis Kirk like $220 well worth it.
Old Nov 15, 2010 | 09:06 PM
Guest
Guest
Posts: n/a
First, you do NOT need a fuel pak. This is a myth perpetuated by the purveyors of add-on fuel management systems in order to stay in business. Back in the days of carburetors, you had to change jets to compensate for the additional air flow. However, today the stock FI is more than capable of adjusting to a different A/C and/or exhaust, as long as you do no internal engine modifications. This is the entire purpose of the O2 sensors in the headers.
Second, a "Fuel Pak" is V&H specific, and doesn't work well with other exhaust. Yes, you have V&H pipes, but the Fuel Pak really isn't a great option even then.
Third, if you insist on getting an add-on controller, the most cost effective way to go is the Nightrider X14iED at around $100. This works in concert with the stock FI, but tricks it into running at 14.0:1 AFR, rather than the 14.6:1 AFR that HD is required to tune into your bike.
Old Nov 15, 2010 | 09:17 PM
xFreebirdx's Avatar
xFreebirdx
Ummm your way off base with that. The stock FI will NOT adjust that far. He may not need a fuel pack but he will need to do something to keep from burning up his motor............
