Charging problem
Old Nov 23, 2010 | 09:14 AM
cHarley's Avatar
cHarley
Originally Posted by yellowsporty
Do you keep your batteryy on a battery tender?
That's not going to matter much if his charging system isn't working, other than to give him enough juice to get stranded 30 miles from home.
Old Nov 23, 2010 | 03:49 PM
hig4s's Avatar
hig4s
If you are going to get stranded, you might as well do it right.
Old Nov 23, 2010 | 05:26 PM
xtremess's Avatar
xtremess
5th Gear
i have a freinds with a sportster bible and i ran a test on my rectifier.. it failed.. i replaced it and everything is perfect, voltage at the battery is right on... so it was the rectifier... thanks for everyone input..
Old Nov 23, 2010 | 07:33 PM
hig4s's Avatar
hig4s
Back on the Road Again!
Old Nov 23, 2010 | 08:28 PM
RidinWrenchin's Avatar
RidinWrenchin
Stage II
Could be that you have a bad battery cable. Disconnect the battery and check the battery cables with an ohm meter. Should have less than one ohm resistance on both cables. Or use a voltmeter with the battery installed and check for a voltage drop. The higher the voltage drop the worse the cable. Either way put your test leads on either end of the battery cable(s). Check one cable at a time. My '04 XLR snapped the lug on the ground cable where it bolts onto the top of the engine cases. Good Luck!
Khshockey44
Electrical/Lighting/Alarm
Aug 19, 2018 02:15 PM
Mthunni
Jun 18, 2018 09:06 AM
adamk
11
Mar 31, 2015 04:22 AM
CarolinaThunder
Jan 27, 2015 02:39 PM
guitarman023
Apr 2, 2012 09:43 AM
