Pegs connector
Old Jan 28, 2011 | 09:58 AM
PktChg's Avatar
PktChg
Default Pegs connector
What's the thing the pegs bolt to?? I picked up a set of pegs that are a bit too big and need to replace those "things" with one's that have a slightly larger opening.
Old Jan 28, 2011 | 11:14 AM
TennesseeMustangPerf's Avatar
That thin is called a motorcycle.
You mean the frame?
Old Jan 28, 2011 | 11:15 AM
Should have a slip pin that goes through the frame tabs and the footpegs, then secures into place with a c-clip.
Old Jan 28, 2011 | 12:14 PM
Pagan48's Avatar
Pagan48
Didn't say what model Sportster you have. If it's a Forty-Eight the regular pegs that fit probably every other Harley won't fit, they're too big. You have to get a mount (Clevis) off a nightster or grind/sand down the peg mount to fit into the Forty-Eight mount. Don't know why Harley did this but it is what it is.
Old Jan 28, 2011 | 03:04 PM
Booey424's Avatar
Booey424
It's called a clevis. Also sometimes caled a peg mount. I took my clevis off and had I had it chromed. The dealer told me they don't sell chrome ones
Old Jan 28, 2011 | 05:29 PM
PktChg's Avatar
PktChg
I have an '01 1200C and I'm not referring to the frame of the bike itself. What I am referring to is the piece the peg bolts to (it has an allen bolt inside the middle where the peg connects in) that allows you to fold it back if needed. If I were to ask for this part would I just reference it as a Clevis or something else?
Old Jan 28, 2011 | 07:19 PM
Daniel Hunter's Avatar
Daniel Hunter
The part is called a footpeg clevis.
Old Jan 28, 2011 | 07:20 PM
Daniel Hunter
Actually your dealer was wrong.
Harley makes them in black and chrome. When I ordered a new set for my 48 the black ones were on back order so I settled for the chrome ones.
Old Jan 29, 2011 | 09:46 AM
SpoilSport's Avatar
SpoilSport
Do you mean this?
FOOTPEG CLEVIS 3/8-24" ... Drag Specialties P/N DS-253492 18.95
The size is universal, so if the pegs do not fit it may be an issue with the peg itself, and not the clevis. You may want to re-check with the maker of the peg as to what size they are (or suppose to be). Chances are that if you get another mount, it will be of the same size and the peg still will not fit.
eSBe
Aug 8, 2017 05:29 PM
Sicktooth
Jul 3, 2015 09:39 AM
burnsy87
Oct 18, 2014 04:30 PM
Barry Powers
Jan 31, 2011 06:44 AM
obonaven
Apr 2, 2009 07:29 PM
