Primary Chain Adjustment
Old Feb 2, 2011 | 10:08 AM
kelton3's Avatar
kelton3
Default Primary Chain Adjustment
'91 XLH 1200. I've adjusted my chain several times using a lift, putting the bike in 5th, turning the wheel, and finding the tight spot, and bringing to specs. One thing I have never done is double checking the chain once the bike is off the lift (cold). This time I did (cold) and the chain was super-tight with no play at all!
From now on my chain adjustment will be done on the ground. No manual, video, or other ever mentions this difference. Anyone else knows about this?
Old Feb 2, 2011 | 10:23 AM
Mike T's Avatar
Mike T
Check it in neutral without turning back wheel.
Old Feb 2, 2011 | 04:49 PM
Zimbob's Avatar
Zimbob
Have you checked the tensioner?
Old Feb 2, 2011 | 05:21 PM
kelton3's Avatar
kelton3
The tensioner has some wear, but not a lot. I'm just curious and now careful when making the adjustment. I suggest anyone who adjust their primary chain with the back tire raised, check it again when lowered.
Old Feb 2, 2011 | 05:29 PM
cHarley's Avatar
cHarley
It's also very easy to wind up with it too tight if you allow the adjuster screw turn even a little bit as you're tightening the lock nut.
I've never seen any difference whether the bike is on the ground or on a jack. It will affect drive belt tension, but it shouldn't affect the primary chain.
Old Feb 2, 2011 | 05:40 PM
Scuba10jdl's Avatar
Scuba10jdl
Agreed. It should not matter for the primary. It has no part that is dependent on ride height/weight like the swing arm. If it is changing, something is wrong.
Old Feb 3, 2011 | 10:53 AM
kelton3's Avatar
kelton3
I wouldn't think so either. Try it. Adjust the primary with the bike raised, the lower the bike and check the tension.
Old Feb 3, 2011 | 11:12 AM
xFreebirdx's Avatar
xFreebirdx
Unless you have a tight clutch where it grabs some with the bike in neutral.
It shouldn't matter if the motor is even in the bike when you adjust the primary chain.
I'm not saying your crazy but you might want to find out why its changing. IE: Charley's Your tightening the adjuster while your locking it down or your clutch is grabbing and needs to be adjusted.
Now you got me curious. lol
Old Feb 3, 2011 | 03:05 PM
martinbastin's Avatar
martinbastin
For instructional purposes only for this post, I checked my 2000 Dyna SG off the ground and then again on the ground and found no difference. 5/8" cold both ways.
Old Feb 3, 2011 | 05:03 PM
Osco's Avatar
Osco
Account Deactivated
I checked mine on the ground,
Put It In gear and rolled for max slack on the top of the chain,,
then rolled off the slack and went back to Neutral.
5,000 miles,,,needed no adjustment.
Iarecobra
Jun 25, 2014 12:28 AM
sskimber
Feb 16, 2014 11:07 AM
thomasf59
May 12, 2008 09:34 AM
bdwjdw
32
Apr 5, 2006 04:07 PM
softail 99
Oct 9, 2005 12:23 AM
