Tank Sealer
Old Mar 9, 2011 | 03:43 PM
markdt's Avatar
markdt
Default Tank Sealer
Ok, so after trying 3 times to seal a small leak in my gas tank I have finally given up on Kreem. I took the tank off, rinsed it out with water, found and welded the small crack, pressure tested it under water at 40 psi, and now I need to reseal it. Is there a product out there that works with the new methanol fuels. It seems that the Kreem product is not compatible with alchohol. Any Ideas..
Old Mar 9, 2011 | 06:28 PM
Mike07FLHTC's Avatar
Mike07FLHTC
eastwood.com sells a kit should be good for all fuels. also KBS coatings.
joshlewis33
Aug 10, 2015 03:14 PM
kris0082
Apr 27, 2014 06:53 AM
MatSubZero
Apr 19, 2011 05:34 PM
jtmurph00
Sep 16, 2009 09:05 PM
1986FXST
Jun 1, 2008 08:13 AM
