Lower Tire Pressures?
I am just getting back into riding after many years, and am just wondering.
Thanks.
Not much lower, just a few psi.
Most bikes list different pressures for 2 up, plus not everyone weighs the same.
Shocks and fork work is what you need to get a good ride tho, tires can not make up for really bad shocks.
My stock shocks were totally worthless.
If you over/under inflate you really aren't helping anything unless you are hot rodding. Also, over inflating is liable to blowout if you heat up the tire a lot and it will wear through the center of the tread quick. Under inflating will be hard to control and will run through the outside of the tire first.
a good seat Is primary,,Mustang Vintage Solo keeps my *** happy,,
12.5" wide for me,,,37" waist an my wife says I got no ***...
Better, faster shocks next,,
Our stock sportster shocks are weak and under damped.
Made for 165Lbs rider,,,when new.
I'm 190 Lb nekkid,,,235 In gear with sissy bar and luggage.
I run the most preload and
38R 33.5F tire pressure,,
5k miles and my rear is not getting the flat spot from straight line rides,,
Course,,I'm a corner junkie XD
You run low pressure down here In Hot sticky florida an yer askin for a tire failure.
Sidewall Flex= heat.
