need help, won't start
Old Mar 27, 2011 | 06:20 PM
kraznos's Avatar
kraznos
Default need help, won't start
1988 883 sport. Cranks but won't turn over for more than 1.5 secs. Battery good-spark good-fuel delivery from petcock good-when I twist throttle gas spurts into carb-good gas, but it just cranks away and wont light up. Any advice would be great as I'm far from being a mechanic.
Old Mar 27, 2011 | 07:17 PM
Edster 69's Avatar
Edster 69
I think you flooded her!
Old Mar 27, 2011 | 07:19 PM
Von_Zipper's Avatar
Von_Zipper
Possible causes:
0. Bad battery, won't give enough amperes. Quite common with batteries that have been discharged and forgotten.
1. Battery cables are not making good contact.
2. Too advanced ignition.
Old Mar 27, 2011 | 07:20 PM
H@mbone!'s Avatar
H@mbone!
Pull the plugs check if there flooded next thing it could be the ignition module. Mine went out on my 86 and seemed to have good spark but not enough to fire it up. And check your battery and battery cables make sure both of them are in working order.
Old Mar 27, 2011 | 07:26 PM
stevelonewolf's Avatar
stevelonewolf
Get an inline spark tester($10.) that one end plugs into the spark plug and the other end plugs into the spark plug wire and check for spark in front and rear cylinders. No spark? either your plug wire(s),coil(check wires going to coil from ignition) or ignition module may be the culprit.
Old Mar 27, 2011 | 07:37 PM
kraznos's Avatar
kraznos
thanks I'll try .
Old Mar 27, 2011 | 08:11 PM
H@mbone!'s Avatar
H@mbone!
Good point forgot to mention the coil
Old Apr 8, 2011 | 09:33 PM
kraznos's Avatar
kraznos
turned out to be some wires shorting out comming from the starter button. thanks a ton guys for all of your advice I really appreciate your help.
NefariouSaul
Feb 19, 2016 09:35 AM
Reign83
Shovelhead
Jun 29, 2014 07:03 PM
sammer4u
May 27, 2011 10:27 AM
ratWynx
Engine Mechanical Topics
Sep 18, 2010 03:06 PM
clove07
Shovelhead
17
Aug 17, 2009 11:41 PM
