Front Locking Up - Help Please!
Old Mar 28, 2011 | 10:49 AM
tony2x's Avatar
tony2x
5th Gear
Default Front Locking Up - Help Please!
Hi, I have a 2003 833 custom. At the end of last season my front brake locked up on me while riding. I bled the brake, which released the pressure, and I was able to make it home just using the rear.
Recently I have been working on the problem, and figured it would be the master cylinder to blame. There were a couple o-rings in the master that were questionable, so I rebuilt the entire thing. Put it back on, and the brakes still locked up.
Next I rebuilt the caliper, still locked up.
So I figured it could be the line because I have heard that they can fail internally causing a check valve situation which doesn't let the fluid back up. Replaced the line and still locking up.
I'm at a loss for what to do. Am I missing something simple? Can there be something wrong with the lever itself? Any help is greatly appreciated.
Old Mar 28, 2011 | 11:48 AM
ogh11756's Avatar
ogh11756
Have you checked the rotor???
Rotor could be warped or cracked.
Did the brakes pulse before locking up??
Old Mar 28, 2011 | 12:06 PM
1CdnHD's Avatar
1CdnHD
Not sure how you are bleeding your brakes, but if you are 'pumping' the lever and the master cylinder piston is returning and exposing the relief port then it's most likely not your master. Where is your caliper piston, ie are your brake pads worn and your piston at the end of it's travel, pins in good shape? Are you using compatible brake fluid for the 'rubber' items in your system? Was the bike worked on prior to the brake failure?
Old Mar 28, 2011 | 12:30 PM
tony2x's Avatar
tony2x
5th Gear
the rotor looks good...there is no pulse before they lock up, I use the brake a couple times and then they lock as I am riding, kind of gradually, until it becomes completely locked. The locking usually occurs when I am NOT pulling the lever in
Old Mar 28, 2011 | 12:45 PM
tony2x's Avatar
tony2x
5th Gear
when I rebuilt the master, it looked as thought the relief port was functioning properly.....the pads are in good condition, and the whole caliper assembly looks to be in good shape
this bike takes Dot 5 and that's all I have put in there when I flushed the old stuff out
Not sure about the history...bought the bike used with 3000 miles on it about a year ago
Old Mar 28, 2011 | 01:59 PM
Spur56's Avatar
Spur56
You might try filling the master cylinder from the bleeder using a syringe. Lower the level in the master cylinder and force fluid through the bleeder. This should tell you if you have an obstruction somewhere. Sounds like the relief port may be clogged. Sounds like as the brake fluid heats up and expands it has no where to go and causes a hydraulic lock. DOT 5 will expand with heat more than DOT 3 or 4. This method might also help clear any gunk in the relief port.
Old Mar 28, 2011 | 02:08 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I had the same problem on another brand bike I owned and it was a hairline crack in the MC. New master cylinder fixed. I am not saying this is your problem, but something worth checking for.
Drew
Old Mar 28, 2011 | 02:17 PM
tony2x's Avatar
tony2x
5th Gear
so if I understand you correctly, if I push fluid from the bleeder on the caliper up into the master cylinder, I should be able to identify an issue with the relief port?
Old Mar 28, 2011 | 02:19 PM
tony2x's Avatar
tony2x
5th Gear
Drew
I'll try to take a look at it tonight....where was your crack? was it easy to see with the naked eye?
Old Mar 28, 2011 | 02:25 PM
wingman1946's Avatar
wingman1946
Maybe you didn't get the seal area clean enough and the piston isn't retracting??
