Best Fuel Management for Iron 883?
Old Apr 2, 2011 | 08:55 PM
Mark883N's Avatar
Mark883N
Default Best Fuel Management for Iron 883?
I have a 2010 iron 883 and was wondering what is the best fuel pak to go with V&H Shortshots & Screamin Eagle Heavy Breather ?
Old Apr 2, 2011 | 09:17 PM
Aaron48's Avatar
Aaron48
I have the Vance and Hines Fuel Pack on my 2010 48 and it works great Zero problems. It looks like in the fitment section the same controller will work on yours too.
http://www.denniskirk.com/jsp/produc...mmyId=19100003
Old Apr 2, 2011 | 09:30 PM
Mark883N's Avatar
Mark883N
Nice i was actually looking at that one on the same site , best price! just plug it and go ? should i go with that or the "approved" one ?
Old Apr 2, 2011 | 09:42 PM
Aaron48's Avatar
Aaron48
If you have inspections in your state than do the approved one cause if its approved in Cali than its gotta be good in every state that does inspections.
Yes it is all plug and play...Very easy install. You will need to use a HIGH flow air filter and a high flow exhaust.
Old Apr 2, 2011 | 09:43 PM
jdaws's Avatar
jdaws
The Dobeck EJK is a better way to go. You make you own adjustments on the unit to custom tune yourself. With the fuelpak all you have are the numbers that V/H give you.
Old Apr 3, 2011 | 05:47 AM
Guest
Guest
Posts: n/a
It depends on what you want.
Are you looking for power? The V/H is not considered a good unit for this by most people, as jdaws said - no adjustability. Dobeck is a decent unit, Power Commander is a good unit, Screaming Eagle is the best unit - most adjustability, greatest range of adjustments.
Are you looking for reasonable cost? The Nightrider X14iEDs are the second best "bang for the buck," as they are only $100 for the pair, and under five minutes to install. The best inexpensive tuner is the stock ECM. It will compensate for the exhaust and intake changes just fine, no need for any add-on.
Old Apr 3, 2011 | 09:38 AM
883_dave's Avatar
883_dave
Check out the Dynojet Power Vision from Fuelmoto. I really like mine so far. Very easy to use and no install because it does not stay on the bike. It gives you lots of options if you plan on doing more upgrades in the future (1200 kit, cams, etc.). If you buy it from Fuelmoto they can have it pre-loaded with a custom tune for your upgrades. I took me less than 5 minutes to re-flash my ECM and the tune is good.
Old Mar 18, 2014 | 05:44 PM
PatoConcha's Avatar
PatoConcha
Sorry wrong thread lol !
rzrectd
May 22, 2024 01:27 PM
Fieldz
Apr 17, 2013 02:58 PM
Mark883N
Apr 11, 2011 08:07 PM
Matrix_Prime
Jun 10, 2010 12:15 AM
killbillr1
May 29, 2009 08:24 PM
