Random Shut Off
Old May 8, 2011 | 08:37 PM
HarleyMan1983's Avatar
HarleyMan1983
4th Gear
Default Random Shut Off
Went for a ride today only to have the bike randomly shut off and leave me stranded on the side of the road. It has done this once before but after it died I gave it a couple of minutes and she fired back up no problem. This time I wasn't so lucky. The bike just died like it was running out of fuel so I quickly dumped the clutch and pulled off to the side of the road. I double checked the tank and I would estimate it to be half full. After a dozen or so failed attempts to start the bike I finally broke down and called a friend with a pickup truck for a lift. The bike is a 1999 sportster sport. I had just changed my oil and filter earlier in the morning as well as cleaned her off with a hose. Is it possible that water somehow got into some of the electrical. Anyone else experience any similar problems? Any opinions or suggestions are welcome.
Old May 8, 2011 | 09:24 PM
jkinner's Avatar
jkinner
Not to be a smart *** but did you switch to reserve on the fuel valve?
Old May 8, 2011 | 10:48 PM
wahlumsurfer's Avatar
wahlumsurfer
How old is your battery? Loose connection?
Old May 8, 2011 | 10:56 PM
jthepipeguy38's Avatar
jthepipeguy38
IF it did it before coil maybe shot??
Old May 8, 2011 | 11:30 PM
tingchiyen's Avatar
tingchiyen
Encountered that before on a friend's HD turned out to be a loose battery connection. You might want to check that first.
Old May 9, 2011 | 01:11 AM
br401k's Avatar
br401k
negative side of the battery
Old May 9, 2011 | 06:25 AM
woodworking1's Avatar
woodworking1
If the bike started after the wash, it isnt water related.
I would check the coil, but it's a shot in the dark. If it's acting good, it will read good.
It could also be the ignition module. They act up when hot if they are going bad.
Maybe the fuel filter.
Definitely check all your battery connections.
Good luck!
Old May 9, 2011 | 07:30 AM
WVHogRider's Avatar
WVHogRider
Check your VOES and the vacuum line going to it. The line may have dry rotted and is not allowing fuel to flow because the vacuum is leaking. Also check the 90* connectors on the coil. Pull the connector and give them a real good squeeze so you can hear it sliding back on the ridged stud. I had both happen to me leaving me on the side of the road for a while. Your battery and everything should be fine since you're able to crank it over and it just acted like you ran out of fuel. When my 90* connector loosened up, the speedo power and needle were jumping/turning off as the bike started sputtering. When the vacuum line rotted all the way through, it just stalled as there was no gas flowing.
hdgeno777
Aug 31, 2015 12:11 AM
dynamac
Oct 12, 2010 07:06 PM
jrdobbs
Jul 15, 2010 11:58 AM
FXDF MYK
May 1, 2008 08:56 PM
mcgehee1946
Exhaust System Topics
Jul 21, 2005 12:46 AM
