Wrapped exhaust
Old May 22, 2011 | 12:43 PM
Kman Harley's Avatar
Kman Harley
I did mine. Mine is a '99 with the cross pipe which was a bit of a pain to do but yours would be easy. I left the heat shields on cause it makes them look beefier and I also left a little of the heat shield exposed at the end to give a chrome lip. One tip I'd give is to put a fold in the ends where it starts and end so it doesn't frill out and keep them behind it so you don't see the ends either - cleaner looking.
Here's a pic of mine
Old May 22, 2011 | 01:35 PM
sorensentyler's Avatar
sorensentyler
kman harley, your bike is awesome.
Old May 22, 2011 | 03:58 PM
streetfighter06's Avatar
streetfighter06
$10 to paint them. Mine were chrome and look great after 2 years now....
Old May 22, 2011 | 07:04 PM
brantwalton1's Avatar
brantwalton1
6th Gear
Did you do anything prior to painting them. Sand them or anything?
Old May 22, 2011 | 08:15 PM
sorensentyler
yeah you're gonna want to sand the chrome... scuff it up a little bit wipe it down, prime it, then spray the high heat balc paint. couple coats. then start your bike up and let it cure. should be instructions on curing right on the can. good luck! post pics when you're done.
Old May 22, 2011 | 09:20 PM
DFsporty's Avatar
DFsporty
I did exactly this and with 5min of the bike running the paint peeled off..lol..so I just wrapped them. Good Luck man
Old May 23, 2011 | 12:30 AM
Pixiechitos's Avatar
Pixiechitos
Old May 23, 2011 | 07:58 AM
Kman Harley
Thanks! It is my first bike build/restoration so I think I did ok.
It might have stripped because you used a non high heat primer or the surface wasn't cleaned or sanded/scuffed enough. Getting a chromed exhaust painted properly can be tricky and tedious.
Old May 23, 2011 | 09:13 AM
DFsporty's Avatar
DFsporty
I used a high heat primer but I probably didn't scuff them up enough...the mufflers are fine but you are correct very tricky and tedious. I wrapped them and really like the look of them.
blackpullet
Feb 10, 2012 10:52 PM
Nick
Exhaust System Topics
Jul 10, 2011 05:31 AM
doer
Dec 17, 2010 11:39 PM
BadGuyNYC
Jul 22, 2009 10:40 PM
bhick21
Dec 17, 2007 06:41 AM
