A/C?????
Old Nov 5, 2006 | 08:35 AM
slick hd's Avatar
slick hd
Default A/C?????
Okay here we go 06 1200 custom can i just replace the stock filter with a K@N and not have replace the backing plate and eveything else? Would useing this set up make my bike to lean? thanks for the feed back on more A/C Slick
Old Nov 5, 2006 | 10:09 AM
diablo666's Avatar
diablo666
Default RE: A/C?????
Yes you can buy the filter and install it.You will need a rejet though.For the difference in money you should just get the entire kit with the backing plate and then do the rejet.That of course is just my opinion.Hopefully you have already done the exhaust to get the most performance bang for your buck.
Old Nov 5, 2006 | 10:28 AM
rbcss's Avatar
rbcss
I thought k&n made a filter for the stock set up. if your leaving your bike stock and not using a hi-flow a/c set up you should be ok.
Old Nov 5, 2006 | 10:29 AM
Thumper26's Avatar
Thumper26
You will get no increase in air flow with the stock backing plate - it is restricted...
Old Nov 5, 2006 | 01:11 PM
LAZYBOY's Avatar
LAZYBOY
i tried the k&n filter in the stock can. with slip ons i still ran lean. checked around local indy shops and found a take-off Kuryakyn a/c with a k&n filter for $100.00. $70.00 for rejet and life is good. it's not that pricey to complete the stage 1. big bang for little $$ imho.
i find it amazing that the rich guys switch out chrome goodies so often just for the current fads. do some calling around.
Old Nov 5, 2006 | 01:54 PM
128auto's Avatar
128auto
I vote Big Sucker, it is awesome, the integrated crankcase vent backing plate assembly is well made. You do need a re-jet though.
How much to buy a K&N alone? I paid $$79 for mine on ebay plus $34 for the cover, dyno test $40 plus main jet $4. There you go!
giacomo56
Milwaukee Eight (M8)
14
May 12, 2018 11:36 PM
El Chiguete
Sep 9, 2016 08:19 AM
mikeallenbrown
Sep 21, 2013 03:42 AM
rooti
Jul 11, 2011 10:12 PM
vettedog72
Sep 25, 2007 11:17 AM
