primary cover
Old Jun 28, 2011 | 07:48 PM
r07sportster883xl's Avatar
r07sportster883xl
Stage I
Default primary cover
a lower bolt on the primary cover broke off of my 2007883xl,ive got the drain plug off,all the bolts from around the outside of cover,both inspection covers off and it still wont come off, did i miss something?
Old Jun 28, 2011 | 08:18 PM
xFreebirdx's Avatar
xFreebirdx
Did you loosen the primary chain tensioner and/or take off the left foot peg and remove the shifter lever. Disconnect the clutch cable?
Are you doing this from a manual?
If you did all that and ensured you removed all the bolts........Then someone might of used Permatex gasket sealer on it and you'll play a bit of hell to get it off. Just be patient and it will come off.
Old Jun 28, 2011 | 08:30 PM
diablo666's Avatar
diablo666
Did the entire bolt head break off?If not it will still hold the primary on.You need to invest in a rubber mallet to tap the cover.At that point you should know what is holding the cover on provided you followed the above suggestions.Even the stock gasket could hold it tight.Thats or threads on the bolt.
jf7689
EVO
Oct 18, 2016 10:14 PM
slipvayne9278
Aug 19, 2011 04:21 PM
vindyl
May 1, 2010 09:31 PM
Legalcarry
Jun 11, 2008 04:39 PM
phat96
Nov 1, 2007 09:48 AM
