Installing Quick Detach Windshield
Old Nov 10, 2006 | 07:53 PM
gmpm5754's Avatar
gmpm5754
Default Installing Quick Detach Windshield
Just picked up my new quick detach windshield from harley part # 58063-04 on my lunch break. Was reading the instructions on my way back to work and it sounds like a pain. Has anyone done it and is it as bad as it sounds? One picture has the throttle cable completly off the handle bar and looks tough. I have a 2007 1200C custom.
Old Nov 10, 2006 | 08:39 PM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: Installing Quick Detach Windshield
The instructions make it sound much more difficult than it really is....
You might check out the following bikernet article (with photo's) in which they install a quick disconnect windshield on a '04 Sportster....
(Also shows them relocating the rear signals for mounting saddle bags)
http://www.bikernet.com/sportsters/P...asp?PageID=623
Old Nov 10, 2006 | 08:44 PM
sgreen0313's Avatar
sgreen0313
It's not that bad. Putting the clamps together is a small PITA, but you only have to do it once. Should take you about 15 mins. Just make sure that you have plenty of soft space to work with that you can lay the shield down on and it will make it easier.
Old Nov 10, 2006 | 08:55 PM
mountainmistress's Avatar
mountainmistress
They scratch really really easy. The same day I put mine on... I scratched it. [:@]
Old Nov 11, 2006 | 12:45 AM
gmpm5754's Avatar
gmpm5754
Thanks for the advice. It took a total of 10 minutes. No cables to move or anything. Looks a little funny, just not used to it yet. Can't ride tonight, might wake the neighbors. Will ride to work in the am and see the results. Thanks for the replies.
Randy
Old Nov 11, 2006 | 01:11 AM
rharrison's Avatar
rharrison
You will enjoy the windshield on the road...I agree...be careful...mine scratches easily. Avoid using harse cleaners. I find soap and water work well.
melstage
Aug 6, 2017 08:36 AM
psidaho
Aug 8, 2014 05:35 PM
AmericanMuscle
Sep 19, 2012 05:30 PM
Sleeko
Aug 23, 2010 01:56 PM
nycfxdl
Nov 23, 2007 08:55 PM
