Headlight switch
Old Aug 8, 2011 | 08:06 PM
reecenos's Avatar
reecenos
2nd Gear
Default HELP on headlight switch
I bought an 07 883 sportster and the Low beam light didnt work I just figured that the bulb was bad I have changed the bulb and still nothing, I have tried to check the wiring and it seems ok, could this be a bad switch? And where can I find a switch other than the Harley dealership? Any and all help would be greatly appreciated!! Thanks~!
Old Aug 9, 2011 | 08:06 AM
HarleyScuba's Avatar
HarleyScuba
When I had an issue with my low beam a few years ago, it turned out to be a connector under the gas tank. One of the wires came loose in the connector housing because the tiny plastic pin that holds the terminal in place was broken.
Old Aug 9, 2011 | 09:29 AM
Scuba10jdl's Avatar
Scuba10jdl
Your best place to find replacement switch clusters (horn + dimmer come as a unit for sportys) would be a independent shop. I found one off a Heritage, which is the same as mine, that the shop tech took off when they converted handlebars and switches for a custom job. It only cost me $25 compared to the dealer.
Crossbones
Jun 24, 2012 07:31 PM
Crossbones
Jun 24, 2012 06:36 PM
LetItRide
Apr 6, 2012 05:59 PM
Whisper365
General Topics/Tech Tips
Oct 26, 2010 11:04 PM
chidiver
Mar 2, 2010 06:04 PM
