Headlight help
Old Oct 6, 2010 | 07:39 PM
Whisper365's Avatar
Whisper365
Stage IV
Default Headlight help
Replaced the headlight switch on my 99 Harley and the low beam still doesn't work. Anyone have a suggestion on what it could be? Thanks
Old Oct 7, 2010 | 12:59 AM
Bluetoys's Avatar
Bluetoys
assuming you have not just assumed it is a good bulb, have you checked for power at the wire? at the switch?
Old Oct 8, 2010 | 10:58 PM
Nute's Avatar
Nute
Does the hi beam come on and go off when you activate the switch? I'm pretty sure there is a relay that actually turns your hi/lo beams on/off. Check and make sure the Hi Lo elements in the bulbs are good with an ohm meter. If they're both good then I would suspect it's the relay. It could also be the switch itself but I'd be more inclined to think the relay is gone. Very easy to change the relay and your stealer should have one to suit.
Old Oct 26, 2010 | 11:04 PM
FLHTom1948's Avatar
FLHTom1948
Get a hold of a cheap ohm meter and do what Nute says, not being flippant; just practical.
clockman
Electrical/Lighting/Alarm
Nov 26, 2017 12:34 PM
Crossbones
Jun 24, 2012 07:31 PM
Route66rider
May 26, 2011 08:38 PM
chidiver
Mar 2, 2010 06:04 PM
Spur56
Mar 2, 2010 05:41 AM
