Throttle Fatigue
Old Aug 10, 2011 | 10:50 AM
mikeallenbrown's Avatar
mikeallenbrown
Default Throttle Fatigue
Loving my Harley...but, after 50 miles my right hand is done! My left doesn't get all that tired. I can just let go, shake it off and stretch out my hand a bit and I'm goodto go. But my right is a different story. I guess its the vibration or something. But my hand starts to get the pins & needles. I tried riding with no gloves thinking that was the issue but it wasn't. My riding position is actually quite comfortable with forward controls and min-apes. When I first start out I feel great but then towards the end I just want to get off.
Is this typical? ...maybe something I just have to get used to? I haven't mounted a windshield ...I'd rather not, but maybe that would help? I'd love to go on long rides but it just isn't possible right now.
Advice?
Old Aug 10, 2011 | 11:03 AM
aqcr_28's Avatar
aqcr_28
i get like that from time to time as well, usually because I'm gripping the throttle a little too tightly. I usually just loosen my grip and wiggle the fingers and then I'm good to go.....
Old Aug 10, 2011 | 11:16 AM
xFreebirdx's Avatar
xFreebirdx
There are exercises that will help with that.
And no its not spanking the monkey either. lol
Old Aug 10, 2011 | 11:30 AM
heybaylor's Avatar
heybaylor
adjust your throttle friction to hold the throttle at any position.
but no so tight that you cannot roll it on/off..
then you can relax your hand , and even take it off the grip every so often..
I often ride 2-3 hundred mile days with no tingle/cramp..
matter of fact , I couldnt without the friction control.
simple movement of the thumb-actuated friction wheel becomes as natural as shifting gears.
Old Aug 10, 2011 | 11:41 AM
cHarley's Avatar
cHarley
+1 - and adding a Throttle Mate makes it even easier.
DeD Fred's Avatar
DeD Fred
I ride 150 miles a day.
I use a throttle dampener.
Not a throttle lock, makes freeway driving effortless
http://throttlemeister.com/
Old Aug 10, 2011 | 12:42 PM
badbs101's Avatar
badbs101
If you've got apes, your hands could be up too high. Lower bars improve blood flow to the hands.
Old Aug 10, 2011 | 12:48 PM
mikeallenbrown
I rotated them back a little yesterday. I'll look into lowering them a little too.
To everyone else:
Thanks for the suggestions ....I had forgotten about my friction lock
Old Aug 10, 2011 | 01:40 PM
kalibear's Avatar
kalibear
I use a Throttle Rocker II on my Nightster, easy on and off, helps reduce fatigue and soreness and you can stretch out your fingers
Old Aug 10, 2011 | 02:07 PM
mikeallenbrown
I don't see how throttle rocker II works ...looks like it wraps around the end of your throttle but then what? ...the entire grip twists ....I must be missing something, lol
