Rear brake pedel not illuminating brake light
Old Aug 22, 2011 | 11:31 AM
rolodog's Avatar
rolodog
Default Rear brake pedel not illuminating brake light
Only my front brake lever lights my brake light. The dealer says a $25.00 solenoid is probably the culprit (one hour labor). Any one have this issue before?
Old Aug 22, 2011 | 04:10 PM
black2000's Avatar
black2000
1st Gear
Hey, hows it going i had this problem about two months ago i lucked out the the wires had come off. Sorry that probably doesnt help but it looks as if it would some what easier with the battery out. Good luck.
Old Aug 22, 2011 | 04:15 PM
rolodog's Avatar
rolodog
Black2000...where are the wires? Are they near the rear brake lever or closer to the rear wheel?
Old Aug 22, 2011 | 04:25 PM
TennesseeMustangPerf's Avatar
Check the voltage at the light, then follow forward. Find out where you are getting voltage, and there is your problem. In other words, no voltage at the light, move to the solenoid. No voltage there, move on to the switch. If you have voltage at the switch, it is the solenoid.
Old Aug 22, 2011 | 08:25 PM
FlyinJ's Avatar
FlyinJ
Probably pressure switch close to rear resevoir. I had 2 harley ones go out before switching to a drag specialties one.
Old Aug 22, 2011 | 08:28 PM
gilmour68's Avatar
gilmour68
+1. I've changed several that have failed.
Old Aug 22, 2011 | 08:36 PM
JohnnyC's Avatar
JohnnyC
Same trouble:
My back brake pressure switch is probably all that's wrong with mine too.
I just make sure to also use my front brake all the time.
99octane
Aug 29, 2017 03:08 AM
Madmike76
Electrical/Lighting/Alarm
May 10, 2016 05:15 AM
blackbike
EVO
Dec 17, 2014 06:30 PM
mrush1130
Sep 22, 2013 10:08 AM
Kmarc86
Aug 31, 2013 09:57 AM
