883 to 1200 conversion question
Old Aug 27, 2011 | 11:46 AM
Mich's Avatar
Mich
Default 883 to 1200 conversion question
I have talked to a couple of HD dealers up here in Canada requesting quotes for the 1200 conversion. One dealer tells me that on top of the conversion kits and labour to install I will need a power commander module and 3 hours of tuning (cost of about $1000 canadian) unless I use the SE slip ons, in which case I will not need the PC module and extra tuning. Another dealer tells me that regardless of the pipes I use I will need the extra tuning.
Also, one dealer says 10 hours to install and another dealer says 7 hours to install.
I would expect the HD dealers to be quoting me the same parts and labour but this is not the case.
Any information from people that have done this or know about it would be appreciated. Thanks.
Old Aug 27, 2011 | 12:21 PM
grbrown's Avatar
grbrown
There are two basic ways of doing that conversion, one is to replace only the cylinders and pistons and use your current heads, the other is to fit 1200 Sportster cylinders pistons and heads. If you chose the first of those the pistons are specials, not stock 1200cc Sportster pistons. It will be much cheaper to go the first route.
There is lots of useful stuff in this thread. Worth reading up a bit more before you make a move on this one. Otherwise your Harley dealers will take you down the most expensive route, as well as charge a lot on labour. Do you have a local indy you can try?
Old Aug 27, 2011 | 12:25 PM
wahlumsurfer's Avatar
wahlumsurfer
I went through this with my dealer a few months ago. I went with the SE 1200 kit, but bought it through Zanotti's as it was $300 cheaper. I don't think you can go that route with the new policies that they MOCO has set.
I also bypassed the power commanders and opted for the SE super tuner. This was more preference, but I felt that all the software and equipment the dealer had was more adapt to handle the super tuner.
3 hours tuning is standard and is found across the board. It allows them to properly dial in the ECM and work out any flat spots in your tune. Who ever told you that you wouldn't need a tune after upgrading to 1200cc is full of BS. You won't be able to run directly off of a 883 configuration after changing out jugs/pistons (and heads with my kit).
I was quoted about 8 hours for the install, but I think that is what the shop book states. I'd take it to the dealer you trust most with the work, if they can do it in 7 and you feel that they will back up their work, then cool go with them.
Old Aug 27, 2011 | 12:57 PM
Mich's Avatar
Mich
I don't have time to read the thread link above, I will later on, but I called down to a shop in the States near the Canadian border and the price quoted by them was substantially cheaper then the Canadian price.
I was quoted SE 1200 conversion kit including heads and SE Air filter, SE black shorty slip ons, SE black Buckshot heat shields, complete installation and tuning and the price with pipes was about $1700 cheaper than what a Canadian shop wants for the same thing.
The ferry that gets me near the US shop will be about $100 return.
mhenry
Apr 13, 2012 09:25 AM
hungoverdog
Mar 11, 2010 05:19 PM
evanstock
Feb 24, 2010 07:01 AM
99Sportster
Apr 28, 2008 07:45 PM
skullcrusher
Apr 13, 2006 10:59 PM
