Clutch Lever
Old Sep 4, 2011 | 10:20 PM
Anthonysdad's Avatar
Anthonysdad
Default Clutch Lever
I have an 07 nightster and waitng for the service manual to arrive, in the the meantime I need a little help. When adjusting the cable (via the locknut and adjustment bolt under the rubber boot) do I go by the feel or is ther a better way to go? In other words, when I pull the clutch lever in when should should it grab? Some say right away, some say at 3/4 the way out. I don't want to screw anything up with the actual clutch.
Thanks in advance
Old Sep 5, 2011 | 02:51 AM
Gpsjr10's Avatar
Gpsjr10
That is just your cable slack adjustment and it should leave about 3/8 inch play at the end of the handle. I always set it to where it just starts to put slack in the cable. The adjustment you are looking for is under the derby cover. And it is very sensitive adjustment. You should wait for your manual as it explains it very well.
It will tell you to adjust the screw 1/4 turn out but I usually go just a bit less so the clutch starts to grab a little earlier.
Old Sep 5, 2011 | 02:54 AM
erbilabuc's Avatar
erbilabuc
by feel.
Jsvwrestle
Jun 18, 2018 07:54 AM
glider1993
Apr 10, 2014 12:42 AM
skydude426
Jun 9, 2012 07:36 AM
VARDR
Mar 26, 2009 08:37 PM
DAWG_6
Jul 29, 2007 06:28 PM
