Reserve???
Old Sep 14, 2011 | 10:23 AM
jack56's Avatar
jack56
Default Reserve???
Ran out of gas this morning, switched to reserve & still no gas. I'm new to Harley, one month & about 400 miles, 05 1200c. Is this common? Thanks, JF
Old Sep 14, 2011 | 10:25 AM
dwagar's Avatar
dwagar
Are you sure you weren't riding on the reserve setting?
Been there.
Old Sep 14, 2011 | 10:29 AM
SportyPig's Avatar
SportyPig
Been there.
That was my thought also. And Yep, I've been there too. I think most of us have at one point or another.
It is possible that the petcock valve has gone bad. But those rarely give any problems unless they are VERY old.
Old Sep 14, 2011 | 10:31 AM
inswva's Avatar
inswva
Yep, riding on reserve sounds like the culprit.
switch at 12 o'clock is reserve
switch at 9 o'clock is off
switch at 6 o'clock is on
Old Sep 14, 2011 | 11:09 AM
jack56's Avatar
jack56
Thanks for the replies, just got the bike to work Sounds like I need to take a better look at the petcock. JF
Old Sep 14, 2011 | 11:18 AM
mikeallenbrown's Avatar
mikeallenbrown
ohh ... 6 o'clock is on?? ...lol. Mine is at twelve. The previous owner put on some sort of aftermarket **** that isn't marked.
Old Sep 14, 2011 | 11:36 AM
TennesseeMustangPerf's Avatar
If you were not riding on the reserve, are you sure your tank is empty? Might be a clog in the line or petcock. First culprit would be riding on the reserve, as stated. I would check into that.
Old Sep 14, 2011 | 12:22 PM
Gpsjr10's Avatar
Gpsjr10
Sometimes the **** can be confusing because there is a small arrow stamped onto the front of the **** that is opposite than the handle direction. Look closely I'll bet it is marked on there somewhere.
Old Sep 14, 2011 | 12:56 PM
cHarley's Avatar
cHarley
Forget the arrow or pointer mark.
The **** turned fully CCW is ON, turned fully CW is Reserve. OFF is in the middle of the two.
Old Sep 14, 2011 | 07:52 PM
streetfighter06's Avatar
streetfighter06
Maybe it didn't REALLY happen and instead it was a lucid dream.....
