Not the EPA compliant Harley stage 1 download. It doesn't richen anything. Now if you get a tuner or a fuel pak from the aftermarket those devices will improve the a/f ratio. Not the Harley one. The Harley download has to follow the mandated emission requirements so it will increase rev-limit. Might improve WOT a/f but cruising a/f will remain 14.7-1 for mileage and emissions. What would be the maximum safe limit on stock valvetrain before valvefloat occurs I wonder?
There can indeed be good reasons to continue running your engine past the HP or torque maximum - it has to do with gearing. It is quite possible that you will still find acceleration beyond the max power range in excess of what you might in the next gear at a lower RPM. TOTALLY possible.
