2-1 Debate
Read everything you can about all the exhausts that interest you and at the end of the day, you'll probably conclude that, in general, the best performing exhausts (in the opinions of their owners) are R&B Racing, Thunderheaders, D&D Fat Cats, and V&H Pro Pipes. However, you will NOT find a definitive answer as to which is best because there is NO empirical data to back it up. The exception to that is that there is empirical data to support that a 2 into 1 exhaust performs better than a dual exhaust including those with crossover pipes. Beyond that, it's all just a matter of opinion as to which 2 into 1 exhaust is best.
How ANY exhaust performs for your bike is based on the length and size of the primary tubes, the length and size of the collector, how those match to what your heads will flow and the cams you're using, and what kind of performance you're looking for. So, there's really too many variables to say that one specific pipe is THE ONE unless you try every single pipe available on the market. And, unless you just bought a winning lottery ticket, that's not really feasible.
It's my opinion that there's little difference in what exhausts of similar design (primary size and length, collector size and length) are capable of.
The only thing you can do is just pick one you like, tune with it on a dyno, and experiment with different baffles until you find one that matches the exhaust to the flow of your engine (based on what the torque curve is doing).
But that's just my opinion.
Supposedly, for every bike (actually every engine) there's an optimal length of pipe based on that engine's flow capabilities. Get the pipe too long and there's too much resistance which will adversely effect your top end power. Get the pipe to short and it won't scavenge properly and it will adversely effect your torque. Baffling has a similar effect and changing to different baffles effectively changes the length of the pipe (by changing the resistance to flow).
You get a similar effect with changing the diameter of the pipes. The larger the diameter pipe the more freely it flows and the more top end horsepower you can make. However, your mid-range torque is going to suffer.
The problem is finding the right length and diameter exhaust for YOUR bike. Again, about all you can do is just pick one and then match it to your engine as best you can by experimenting with different baffles.
Here is the link:
https://www.hdforums.com/forum/sport...e-results.html
