Drag bars
Old Oct 20, 2011 | 09:24 PM
Jaystn62's Avatar
Jaystn62
Default Drag bars
I'm wanting to try some 36" drag bars from J&P on my 06 883c. From what I see doesn't look like the front brake line is long enough. Are there many other things that would need to be changed? I'm in no hurry since this is going to be part of the winter projects and any help will be truly appreciated.
Old Oct 20, 2011 | 09:44 PM
barrygreen's Avatar
barrygreen
Depends on what risers you use. Drag bars work with most stock cables unless you go to high with the risers.
Old Oct 20, 2011 | 10:09 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
The brake will be fine. I have 32" and my lines are much too long.
Old Oct 20, 2011 | 10:47 PM
Jaystn62's Avatar
Jaystn62
I'm going to use the stock riser that comes on the 883 Custom. It's about 4 1/2 to 5 inches high.
Old Oct 21, 2011 | 06:26 AM
Ragnar Danneskjöld
I had 6" rise with 32" bars. You should be fine.
Old Oct 21, 2011 | 06:39 AM
streetfighter06's Avatar
streetfighter06
36" seems wayyyyyyy too wide for a skinny sportster. Why not do 27"??
Old Oct 21, 2011 | 02:28 PM
Jaystn62's Avatar
Jaystn62
Because the stock bars are about 30" with the grips and they wearing my old *** out around town when I have to do a lot of stop and go and tight turns.
Nat_Asp_Mike
Apr 6, 2018 05:43 PM
mikesova
Jul 14, 2013 10:12 PM
dazzlyn
Oct 8, 2012 01:41 AM
cke91082
Jun 18, 2009 02:44 PM
Jhorra
Feb 21, 2009 12:13 AM
