99 XL wire to solid wheel swap help needed
Old Nov 2, 2011 | 02:26 PM
soniccbr's Avatar
soniccbr
Default 99 XL wire to solid wheel swap help needed
Hey ya'll, I'm working on swapping a solid rear wheel onto my girlfriends 99 sportster, and I've come to find that Harley changed to sealed bearings in 2000. The 99 used Timken bearings and 3 spacers instead of the 2 spacers with the newer bearings. I'm hoping that one of ya'll can measure the spacers on a 2000 to 2003 and from swingarm side to side.
I have part numbers for the new bearings, but would like to check the sizes so I don't buy a spacer that is the same size as the ones I got.
FYI, if anyone wants to do a wheel swap like this, get a newer style rotor as the size of the hub lip is different also.
Also, has anyone upgraded the brake calipers on a 99 front or rear without spending allot of money? I was hoping the front from my fatboy would work, but its nowhere close. Need pads anyway, so its a good time to upgrade the calipers.
Thanks
Old Nov 3, 2011 | 07:40 PM
soniccbr's Avatar
soniccbr
Anyone got a 2000-2003 sportster they can measure the spacers on?
Anyone know any reason the 2000-2003 caliper won't fit a 99?
Old Nov 3, 2011 | 09:37 PM
mreed's Avatar
mreed
Just put the wheel on, line it up by using the belt and measure for spacers. The mounting is different on the newer calipers. The rear slides on a tab on the swingarm and your current one wraps around it and the front caliper mounting depth is less on a newer fork.
Big Rod
Oct 13, 2014 06:55 PM
patcham48
EVO
Jul 2, 2013 09:31 PM
T-rat
Jan 27, 2013 04:53 PM
SmokinRK
Mar 23, 2012 08:36 AM
nc883
Mar 14, 2012 10:00 AM
