Header wrap
Old Nov 3, 2011 | 02:24 PM
VirgeB's Avatar
VirgeB
Well, me neighbor does want to run his 04 against mine so every little bit helps right? From bottom to top it is.
Old Nov 3, 2011 | 02:28 PM
barrygreen's Avatar
barrygreen
This guy makes it look easy
http://www.youtube.com/watch?feature...SOJYWKU#t=180s
Old Nov 3, 2011 | 02:51 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
You soak it to make it easier to wrap. It sticks a bit better and doesn't move around as you're wrapping (especially if you do it with the pipes on like I did). Also, the reason to wrap it from the back towards the top (for pipes directed like mine) is to keep dirt and random **** out.
Old Nov 3, 2011 | 03:14 PM
barrygreen's Avatar
barrygreen
That also
Old Nov 3, 2011 | 03:39 PM
VirgeB's Avatar
VirgeB
I'm going to have to take the pipes off. There is no way I will be able to do a good job with them on the bike. Guess I will get out a bucket when I get home and soak the wrap for a while before I start.
Old Nov 3, 2011 | 03:44 PM
Ragnar Danneskjöld
I did mine with the pipes on in a car wash bay in 30 minutes. They turned out great.
Old Nov 3, 2011 | 04:38 PM
cHarley's Avatar
cHarley
Be sure and replace the old manifold gaskets when you reinstall the pipes, and I recommend using the SE gaskets, not the stock gaskets.
Old Nov 3, 2011 | 05:19 PM
FlatIron's Avatar
FlatIron
Originally Posted by barrygreen
On your pipes...no... but as the wrap ages I have seen the edges become frayed faster when wrapped from the top down...no joke. Do a search on wrapping pipes and they almost all start at the end and go toward the head, just in case you decide to break any land speed records
in all honesty i was gonna double wrap those bitches so i will do it from bottom to top 2nd time around....
I will let you know how the record breaking goes...lol... wiseass! haha
Old Nov 3, 2011 | 06:45 PM
barrygreen's Avatar
barrygreen
hahahaha
Old Nov 3, 2011 | 06:52 PM
NickD's Avatar
NickD
Don't wet the wrap! No matter what the instructions say. Water is what causes the problems with the pipes deteriorating under the wrap so why introduce it right off the bat? Keep in mind these wraps were developed for thick cast automobile exhaust headers, not thin steel motorcycle exhaust headers.
Yes! Wrap them aerodynamically! Don't wrap from the motor down. Wrap from the tail pipe up. (Again contrary to instructions.) It will start to fray (it's a woven fabric after all) a lot quicker with the leading edge facing into the relative wind.
If you want to do it right remove the pipes. It's the only way you can get it tight and looking right.
Also, if it's typical black, white, or tan wrap coat the wrap with several coats of high temp paint. (Another reason to remove the pipes.) They sell special paint for header wrap but RustOleum has High Temperature Barbeque paint that works just fine. It's available everywhere and at a third the cost. Plan on re-coating every once in awhile as the wrap fades over time. When I re-coat mine I don't remove the pipes I just carefully stuff a bunch of newspaper around the pipes and shoot them just for appearance sake.
Lastly don't use wire ties. Use hose clamps. Once the fabric of the wrap starts to fray and come apart there's no stopping it, so don't let it start. And hose clamps just hold better. Hide the screw heads behind the pipes and paint the clamps to match with the same color high temp paint. Or a contrasting color if you want to go the funky route, LOL!
