Another Cams question...
Old Jan 9, 2012 | 10:49 AM
07HDnightster's Avatar
07HDnightster
Default Another Cams question...
I've done some research, but i thought i'd throw it out here (i'm sure it already has) and see what some other opinions are. Anyhow, my question is; Is there any descent cams that are "bolt in" and that are worth it? Or what do some of you recommend? I'm not looking to out run everyone, i was just looking for a little bit more power without going thru the motor. Let me know what y'all think. By the way, this is for an 07 Nightster. Thanks
Old Jan 9, 2012 | 05:58 PM
woodworking1's Avatar
woodworking1
Cams are useless without the complimenting headwork.
Old Jan 9, 2012 | 08:11 PM
autotechmark's Avatar
autotechmark
Default S&s 551ce
Well I was just looking for some extra launch off the line and I clearly found it with the 551's. The difference is very noticeable but this is on an ultra. Good luck.
Old Jan 10, 2012 | 05:54 AM
xFreebirdx's Avatar
xFreebirdx
+1 Just as Wood said...............
BT's and Sportster motors have nothing in common and this statement should be ignored........
Old Jan 10, 2012 | 11:25 AM
jag1886's Avatar
jag1886
Your engine already has a fairly good set of cams, invest in head work, compression and a good tuner.
Old Jan 10, 2012 | 11:36 AM
Sikk50's Avatar
Sikk50
I've been looking at cams too, just for a little extra help when on the freeway. I'm sad to hear they aren't worth it. The only reason I didn't buy them yet is installation prices are too expensive and someone told me I need a special tool
Old Jan 10, 2012 | 12:20 PM
xFreebirdx's Avatar
xFreebirdx
No special tools are needed. Only thing needed is the service manual for your model and year bike.
Old Jan 11, 2012 | 09:11 AM
07HDnightster
Thanks for the input fellas..
Old Jan 11, 2012 | 12:07 PM
BurpleHugger's Avatar
BurpleHugger
The only special tool required is either internet access for forums such as these, or as xfreebirdz said a service manual. Both are life savers.
Bigfoots03HD
Dec 4, 2015 06:05 AM
quinton82
Jan 6, 2015 02:51 PM
Skip
Exhaust System Topics
Sep 20, 2012 08:13 AM
Biptastic
Jan 6, 2009 06:37 AM
kansasroadking
Jan 21, 2007 09:40 PM
