Is there an easy way to tweak the part of the frame that the rear fender mounts to?
I need to pull it out a little. It seems to be a little close to the tire. Like if it has been bent in.
I know it's steel or iron so i don't know an easy fix. I'm concerned that the bolts from the backrest
and rear turn signals will shred my tire.
First I would take it to the dealer because of warranty issues.
It is not hard to spread the frame with a hydraulic body jack. What is hard is doing it correctly. You don't want to put a twist in the frame. I would enlist the services of a professional motorcycle frame builder/repairer. They will have the proper equipment to measure and repair your frame.
Thanks for the input. I wouldn't have to about warranty, it's a '95. I forgot to mention that. you are right about having as professional do it though. I'm going to check into it this week. Does anyone know of anybody in the Dallas/Ft. Worth area?
