performance
In this web site there is a tab that says sportster on the right hand side. There the will show you proven steps to take that can put you from 75 hp all the way to 103 hp to the rear wheel. WOW man!
A/C, Exhaust, cams, and ignition is what you can do to gain power without rebuilding. That's pretty much all I know. In that order pretty much how you do it with A/C | Exhausts, cams giving you the biggest gains with the ignition module giving you the smallest gains (3 hp at best from the ignition).
As for the mikuni, it won't really give you any signifcant gains unless you have an over 100 hp engine. However, the advantages is has over the CV carb is throttle response. When you open up the throttle with a mikuni carb acceleration is NOW. With a CV carb you get a small delay.
There are lots of infomative steps to this procedure here on the site, so search stage 1 upgrades and you'll be swimming in technical info. The pickup is an average 10-12 horsepower, and if you want more, then cams and head porting are the necessary steps taken after stage 1. This will effectively give you a stage 2 upgrade wih about 90-95 horsepower being the net result. Keep in mind that cams, cylinder heads, and porting can set you back a few grand and they will likely require more carb work, bigger and better exhaust systems, and some dyno time to tune it in right. NRHS out of Colorado is the company to search if you want big Sporty Power, but be prepared to shed thousands to get that added power my friend.
I researched all of this over the past 4 months, and could not find enough valid reasoning to make me give up the added 3-4K just to pick up another 12-20 horsepower. Just wasn't worth it at this stage. Stage 3 upgrades will give you between 100 - 110 hp and it justs keeps costing more money to get those few added horsepower. If all you want is some basic performance, some nice sounding pipes, and a little bling, then go the stage 1 route and realize your biggest bang for the dollar. I just got my bike back today and here are the net horsepower results with an EFI 1200 Sporty. A nice p/u of 15 horsepower and 6ft-lbs of torque at 3600' above sea level. I'm very happy with my results, and my new pipes sound just wicked. See my other post in the Sportster forum titled XL50 on Steroids. I will be adding more pics and video tomorrow night.
think i lean towards the stage one with polish and port and mikuni..
cam i imagine will be the hardest decision. hope the guy doing the polish and port will have some concrete findings to base that decision on.
thanks again all
and MERRY CHRISTMAS
short of a major rebuild what is best route to increase eprformance of 06 1200R. air,pipes cam ignition.. any recomendations greatly appreciated..... looking to spend a 1,000 bucks or so. Have a rk for cruising but would like to have a reliable rod as well....
thanks
