Wide Glide Front End
Old Jan 21, 2012 | 01:25 PM
rickss69's Avatar
rickss69
Originally Posted by dproto09
Is the handling any different with the 150mm up front, compared to the 130mm. I just would hate to go down, I love to lean.
The wider tire has no effect on handling from my experience.
Would you swap, the bearing off the old wheel to the new 25mm or just order the axle kit from vulcan to fit the older wheel.
Just let Vulcan know what model you are working with and they include the correct axle for your bike. Whatever wheel you decide to use simply replace the bearings to match the axle size.
Would you just suggested Drilling and tapping the caps with the air valves of the forks to prevent the front end from bottoming out, or is there a better way?
Chances are you would not encounter this...in my case I was already at reduced travel being a Low model. Overall length of the WG trees are slightly more than stock because of the massive castings, thus you lose a little suspension travel. Better springs than the soft stockers would have been better in my case, but I chose the air option instead.
Also with the Valcon Wide glide, can you drill and tap the top tree to mount the factory head light or does it have to be replace completely?
Can't say for certain as I did not attempt. Just my opinion, but I think the small headlite would look rather odd with those massive trees.
sorry for all the question.
Starting to feel like I'm hijacking someone's thread... Many questions can probably be answered here... https://www.hdforums.com/forum/sport...l-on-07-a.html
Old Jan 21, 2012 | 10:16 PM
GWinkleman's Avatar
GWinkleman
No hijacking here! The title is "Wide Glide Front End" and you certainly have done an amazing job with yours!
South Jersey Scooter Trash
Dyna Glide Pictures
Apr 14, 2022 07:37 AM
apetterez
Mar 2, 2015 08:33 AM
Holster Maker
EVO
Apr 18, 2011 02:10 AM
128auto
May 29, 2008 07:18 PM
tic10
Oct 25, 2006 02:53 AM
