Ripped off!!
Old Jan 24, 2012 | 07:47 AM
bmxatv's Avatar
bmxatv
i see your in pennsy....what dealer? bottom line is, if that's how they advertised and that that's not what you got and they aren't willing to do anything about it, LAWSUIT!
Old Jan 24, 2012 | 07:48 AM
Rog48's Avatar
Rog48
Originally Posted by Scuba10jdl
Stroke is the same. The only difference is in the bore. 3.0" for the 883cc and 3.5" for the 1200cc.
Wow, 1/2" over bore, thats a lot. I assume you have to get new jugs when doing that? Or is there that much meat to them?
Old Jan 24, 2012 | 08:13 AM
Hitechluddite's Avatar
Hitechluddite
Run a tank of gas through it. If you get 50+ MPG it's probably a 883!
Charley How ya doin? I don't drop by much anymore but it's good to see your still here.
Old Jan 24, 2012 | 08:25 AM
8541hog's Avatar
8541hog
Originally Posted by sg34
So I posted I picked up an 09 Iron at the end of last week that had a 1200 kit in it.Well my buddy and I checked it out tonight and it's an 883.I questioned it after I saw the stock A/C.So I guess a trip to the dealer tomorrow to see what they are going to do about it.
So what did you do to check it out? If you knew how to check it out, why didn't you do that BEFORE you agreed to buy?
Don't know about anybody else, but I would want proof positive on such an upgrade before buying it.
Old Jan 24, 2012 | 09:00 AM
Joker_Hal's Avatar
Joker_Hal
If you decide to sue, make sure to through lawyer costs in there as well.
Old Jan 24, 2012 | 09:35 AM
Outtakes's Avatar
Outtakes
You can actually measure the diagonal of the cylinder.
Jack up the rear wheel, take out both spark plugs
put the bike in 5th gear. Rotate the rear wheel
until the piston is at bottom dead center, BDC.
Use a wooden dowel or chop stick to feel when the
piston is at the bottom.
Then push the bottom end of the stick to the far side
of the combustion chamber and mark the end of the stick
where it hits the upper lip of the spark plug hole.
This is the diagonal of the chamber and it will be different
for a 1200 vs. a 883. Your measurements might be close to this.
For a 1200 it will be about 5 7/8"
For a 883 it will be about 5 1/2"
Old Jan 24, 2012 | 09:48 AM
emperor wurm's Avatar
emperor wurm
doesn't the vin tell if its an 883 or a 1200?
Old Jan 24, 2012 | 10:02 AM
cHarley's Avatar
cHarley
Uh, why would the VIN change if the motor was upgraded after the bike was manufactured???
Old Jan 24, 2012 | 10:06 AM
emperor wurm
guess i didnt read the whole thing, I thought he said he bought a 1200 from the dealer which turned out to be an 883.
Old Jan 24, 2012 | 10:52 AM
HarleyScuba's Avatar
HarleyScuba
He did say he bought a 1200 that he suspects is an 883. There's a multitude of methods and parts combinations to make a Sportster that's an 883 into a 1200. All you really need is bigger bore pistons with rings, bored out or replacement cylinders ("jugs") and a gasket set. An 883 that's converted to a 1200 may look 100% identical to a factory 883.
