Bike not starting.. help!
Old Feb 7, 2012 | 09:02 PM
run1fsr's Avatar
run1fsr
Originally Posted by dark and destroyed
@barrygreen: wired the run to the power so when you turn the key the fuel pump starts automatically starts, and wired up a push button start using the black/red and white/black wires. i didnt think the clutch button that the lever hits would effect anything but could be whats baffling me.... ill try it tomorrow
All my junk is older than yours. But when I eliminated the ignition switch on my Sportster, both the accessory and run wires needed to be hot for everything to work. Maybe or maybe not the same for yours but something to check and confirm.
Old Feb 7, 2012 | 09:05 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
How long since it last started?
Old Feb 7, 2012 | 09:29 PM
dark and destroyed's Avatar
dark and destroyed
not sure what wire that is i'd have to investigate to see. it last ran about 3-4 weeks ago and before that a month or so
Old Feb 7, 2012 | 09:44 PM
tripn88's Avatar
tripn88
So the bike is turning over... i never saw you answer that question lol
Did you check all your fuses and relays? ( starter relay went out in truck today)
If you turn key on, fuel pump primes, its in neutral should crank right up obviously. Check your coil to make sure your wires are plugged into the back of it. I dont think it could be from bad gas with all the additives they add now.
Old Feb 7, 2012 | 09:50 PM
dark and destroyed
@tripn88: yeah the bike is turning over. the harness is connected to the back of the coils. not sure how to verify a bad relay other then replacing it. im gonna try and replacing the "system relay", checking plugs for spark and double checking the quick connect fuel line..
Simon Farrell Nutty Qrra
Electrical/Lighting/Alarm
Dec 8, 2015 07:11 PM
TYM2GLIDE
Jul 6, 2015 10:40 PM
2006ultra
Aug 13, 2013 04:21 PM
exemexer
Apr 17, 2010 07:06 PM
Sullyboy
Aug 3, 2009 09:34 AM
