Failed the Fall Away text :(
When I first got it off the ground it felt like it had no resistance at all. So I thought right away, "I needed to tighten this up". After the fall away test, I figured tightening might help but shouldnt have anything to do with all ways wanting to fall to the left.
I broke everything loose and tightened about a quarter turn. It feels like it might help buuuuuut Is it time to replace the bearings, right? or what else could cause this? What bearings are you guys using and where are you buying? Ive searched but I have a lot going on and maybe im searching the wrong things. Please help me out
Also wondering if any one has had any experience with the 3 or 5 degree neck bolt kit???
Falling to the left is not uncommon with the clutch cable hooked up still.
It seems like you know how but just in case:
With the bike jacked up (and level), loosen the 2 lower clamp bolts that secure the lower tree to the fork legs, loosen the one clamp bolt on the upper tree that secures the neck stem and tighten the neck stem bolt until your front end has one to two inches of movement left and right before it falls away. BUT, with the 3 clamp bolts loose, loosen the neck stem bolt a little then retighten until there is no free play in the bearings (up & down)...then begin the fall away test/procedure.
I can't comment on the rake kit. It will change your trail measurement and that may or may not increase your sensitivity to the feeling you're having now.
I also put some grease in the neck when I was checkin out the bearings. I didnt remove everything but I did as you say and i lowered the bike to get the tree apart. The bearing looked fine but had little grease. Is there no zerk fitting? I didnt see what but I didnt really look for one. MAybe in the web of the frame???
I was asking about the rake bolt just incase. If I was going to replace things any way I could just buy the kit. Ive mostly heard about people sayin it will mess with the turns a little but thats fine as long as its not tooooo bad or too ugly
Thanks mreed
Yes, the clutch cable will definitely force the front end to the left when there's no load. It will make left fall seem to easy and right fall seem to tight. You may have it pretty close to "ok" right now actually.
That grease zerk doesn't do anything for the bearings. Sportsters don't even have them anymore. It's more to keep the steel neck stem from rusting. You have to pull & pack the bearings just like old school wheel bearings.
When I had it apart I could see the lower bearing completely. I packed grease on/in it but I figured as long as its lubricated it should be fine.....its a steering neck, not high speed wheel bearing.
I havent test driven it yet. I will today I hope. My problem before was the highway wobble over 65, wobble at any speeed when I remove my hands, and clunking when I do a hard stop. Any ideas on that?
get the slack out the neck, check alignment, tire condition and pressure.
This may help.
http://www.motorcyclemetal.com/downl...e%20Simple.pdf
And to get a proper fall away measurement you will want to remove the clutch cable from the lever.
Im hoping that I got the noise and wobble out of there but well see.
For what it's worth, When I buy a used bike one of the first things I do is rebuild the forks & change the neck bearings. Sometimes the neck bearing races & wheel bearings as well. It doesn't take very long.
