stripped shifter...suggestions.
Old Feb 11, 2012 | 06:08 PM
petewerner's Avatar
petewerner
Bring the shifter out flush with the shaft. Drill a hole that is going in sideways so that 1/2 the hole u drill will be on the shaft going strait toward the engine and 1/2 going thru the shifter then run a tap between the shifter and shaft where the hole was drilled. Like a 3/16" drill and then a 1/4" tap. Be sure and get it lined up where u wasnt it to be, BEFORE u drill it. another way is to drill strait doen thru the shifter and the shaft and put a bolt thru it, easier, not as nice looking and way easier to break compared to the first method!!!
Frozen Crome
Feb 15, 2018 09:14 PM
media1988
Sep 26, 2014 08:43 PM
EvilWayz
Ironhead
Dec 12, 2009 01:19 PM
Sonny's World
Aug 29, 2009 10:07 PM
fireball
Apr 7, 2006 08:04 PM
