Stock Shock Adjustment
Old Feb 27, 2012 | 11:27 AM
GWinkleman's Avatar
GWinkleman
Question Stock Shock Adjustment
Just started riding two-up this weekend. Obviously the bike sits lower than it did with just me on it. Are the stock shocks on the 2012 Iron adjustable at all (to make them firmer) or should I look into buying some new ones? Service manual is at home and I'm at work so I can't go to that first.
Old Feb 27, 2012 | 11:39 AM
JeffKill's Avatar
JeffKill
The preload is adjustable on the stock shocks. It can be done with a tool specifically made for it, or a pair of channel locks.
Old Feb 27, 2012 | 11:45 AM
GWinkleman's Avatar
GWinkleman
Thanks Jeff. I did some more digging through the forums. Looks like I'll be buying a spanner wrench.
Old Feb 27, 2012 | 12:10 PM
BiggDogg's Avatar
BiggDogg
Yes, it's called a spanner wrench. it's cheap, I never understood why one doesn't come with the bike to begin with
Old Feb 27, 2012 | 12:28 PM
exemexer's Avatar
exemexer
Your bike probably is sitting on factory setting (middle setting) as was mine. I'm about 170 - 175 lbs & stock setting is fine except a little bottoming over harsh bumps at speed. You'll wanna go at least one setting firmer at first for 2 up. I think there's only one more after that, but it will make a noticeable difference.
Old Mar 4, 2012 | 09:07 AM
IBGary's Avatar
IBGary
I adjusted my by changing the location. I put them in the trash. I'm running progressive, which makes it ride like a different bike. I can also adjust the preload by hand. Wife on, wife off, 1 minute change with on tools.
Old Mar 4, 2012 | 12:11 PM
Blues Fan's Avatar
Blues Fan
The stock shocks on my '08 were trash for two-up riding. Bottomed out regularly even with the preload cranked up all the way. Changed over to Progressive, what a difference!
Old Mar 4, 2012 | 02:12 PM
scooter1128's Avatar
scooter1128
gw...get yourself some streetglide take offs from ebay and throw some progressive fork springs in the front forks with some new fork oil and youll be really happy with it
Old Mar 4, 2012 | 03:06 PM
CanuckSporty's Avatar
CanuckSporty
X2 The stock shocks are absolute garbage.
Old Mar 4, 2012 | 05:11 PM
IBGary's Avatar
IBGary
Scooter, did you change the front and rear at the same time?
