New Mods - shortshots chrome to black
Old Mar 31, 2012 | 01:34 AM
SpecterGT260's Avatar
SpecterGT260
Default New Mods - shortshots chrome to black
So I wanted black shortshots. They are expensive (which sucks). I happened upon a deal here in town and got some EFI chrome shortshots for a shade over $200. I decided to document this, because I havent seen too much of this done.... I bought some flat black engine enamel good to 2000*F, some 1500 grit sandpaper, and did my install.
A few pics to get things rolling....
Mirror flip (was worthless until I rotated the handle bars forward about 15 degrees... now I can see better than if I were in my truck.
Just pictured for posterity....
So the swap.
Pipes on:
Long heat shield (unsanded or painted)
Short shield sanded and painted
So the 1500 might be a bit conservative.... 800 grit may have been better to get some good swirls going in the chrome for the paint to stick to. The panted shield only has 1 coat on it. I will check it out tomorrow to see where we are at... if it chips too easily I will resand with a lower grit and try again.
anyways, this is not something I have seen too much on around here... and with the black pipes costing significantly more than the chrome ones... if this works out we may all end up with a viable option that saves $50.
I will post more pics over the weekend as I get this put together. worse comes to worst... I will just wrap the pips without shields and ride that way... kinda digging the naked shortshots on the 883N
Old Mar 31, 2012 | 09:04 AM
peiser423's Avatar
peiser423
6th Gear
Looks good so far, the short shots look awesome.
Old Mar 31, 2012 | 10:49 AM
Ployd4's Avatar
Ployd4
Yeah, keep us posted on how it holds up. I've been thinking about removing my stock mufflers, welding on straight pipes, and painting black. I can weld but I've been a little nervous due to the painting. Do you have to bake the paint afterwards, or can you just run the bike to bake the paint on?
Old Mar 31, 2012 | 11:05 AM
Robbie13's Avatar
Robbie13
LOSER
Nice job!
Old Mar 31, 2012 | 08:37 PM
SpecterGT260
So, the paint from last night didn't work out too well. The 1500 grit paper was too nice. While it looked fine, a fingernail was all it took to remove paint (1 coat). So I took the paint off with scotchbrite and went after it again - this time w 220 grit.
See below:
By appearances alone, this gave the paint much more to hang on to.
I got both pipes painted up. This stuff has a tendency to go on thick and to spray unevenly.... but when it dries you cannot really tell anything happened.
I am ~4 heavy coats in (emptied 2 whole cans onto these guys over the course of the day) and the logo lived!
So I think I will let them sit for the next week in the back of my garage an set up before installing them. There were some parts of the instructions about heating them in an oven.... that isnt an option. So hopefully a few short trips when on the bike will do the trick.
If this doesnt work, I saw a can of spray on bed liner I will see if that does anything and then just wrap them up in dark heat wrap and call it a day.
The GF has been all over me about "why would you do this to a bike... that isn't classic harley". We are having a "date night" and watching Mad Max to get her in the proper frame of mind for where this bike is headed.
Old Mar 31, 2012 | 09:02 PM
SpecterGT260
Side question for you guys.... is it OK to put a 3 hole derby cover on this bike? apparently the aftermarket in 6 holes is a little lacking...
Old Mar 31, 2012 | 09:33 PM
streetfighter06's Avatar
streetfighter06
Typically, the grit doesn't matter. I always just scotchbrited my pipes and they held up great. 220 grit is kinda harsh.....
Minimum - do 3-5 coats of paint. Let them sit for a day, not a week and they will be fine. Also, they would looks better black without the heatshields, IMO.
Old Mar 31, 2012 | 09:34 PM
streetfighter06
LOL no, you cannot put a 3 hole derby cover on it.
Old Mar 31, 2012 | 11:31 PM
SpecterGT260
I'm after the black w the chrome tips poking out. Just couldn't find anyone selling a set. Thanks on the derby cover. I was hoping it would mate up. Apparently I get to keep the awkwardly chrome cover on my otherwise black bike
Old Apr 1, 2012 | 04:59 PM
SpecterGT260
So, because I am not one to argue paint issues with a guy who has a DIY chameleon paint scheme, I slapped the heat shields on todady. They got a few little nics in them while putting it on. That 1500 grit paper came in handy again and I buffed them out. However the sanding turned the paint a little darker, with almost a metallic glint to it. Otherwise looks fine. I am going to have to go over everything evenly with the fine grit sand paper to make sure it looks right. I may coat with a clear coat eventually..... probably not
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
