Retention ring
Old Apr 16, 2012 | 03:34 PM
Travis_Turner's Avatar
Travis_Turner
6th Gear
Default Retention ring
After changing out the sift linkage on the 72 this past weekend I realized I had a part left over! It appears that I have the small brass retention ring (incomplete circle with two small holes) still sitting on the mat. Can someone tell me where this piece fits in to the foot peg assembly? Before anyone suggest it, I have already ordered the service manual but I don't have it in my possession yet.
Thanks in advance.
Travis
Old Apr 16, 2012 | 03:57 PM
Martads Bobber's Avatar
Martads Bobber
I may use some busted terminology, but there is a bolt or pin probably 3/8 in diameter that passes through the mounting piece for the footpeg, and through the female "eye" of the footpeg itself. this pin has a small groove on the end, and the retaining ring slips into this groove, keeping the pin from backing out and your footpeg from falling off.
I think.
Old Apr 16, 2012 | 04:04 PM
cHarley's Avatar
cHarley
I think.
+1 That's correct.
Also, the foot peg itself may be attached using a nut and bolt OR a clevis pin that has a "snap ring" on the bottom side. The clevis pin method is the stock setup, but if you changed to aftermarket pegs they may have come with nuts and bolts.
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Note white bucket for left overs. Harleys have too many parts anyway
Old Apr 16, 2012 | 05:25 PM
chappy99's Avatar
chappy99
He He
nitrohound
General Topics/Tech Tips
Apr 25, 2026 06:56 PM
yandeltx
Aug 15, 2018 09:31 AM
smke54
Aug 30, 2014 11:06 PM
Ed45
Oct 1, 2007 09:20 AM
slick hd
Aug 28, 2007 01:31 AM
