Breather bolts - Loctite? Anti-Seize?
Old Apr 27, 2012 | 02:41 PM
ryamatt's Avatar
ryamatt
Default Breather bolts - Loctite? Anti-Seize?
My service manual doesn't say to use anything; I've heard red Loctite, and I've heard anti-seize.
What should I be using on my breather bolts?
Thx.
Old Apr 27, 2012 | 02:43 PM
Scuba10jdl's Avatar
Scuba10jdl
I personally don't use anything, and have never had a problem with them coming loose. If you must use something, go with blue. Red is for things you never want to remove, and this is not one of those places.
Old Apr 27, 2012 | 03:07 PM
simmy711's Avatar
simmy711
What he said...
Old Apr 27, 2012 | 03:09 PM
skjskmata's Avatar
skjskmata
Agreed. No need to use it.
Old Apr 27, 2012 | 04:48 PM
mrfikser's Avatar
mrfikser
the se ac calls for white (high temp) locktight for the breather bolts that go in the head...or at least they did in 2008 on the twin cams...the filter assy. came with a small tube of it...
Old Apr 27, 2012 | 07:37 PM
95th 1200's Avatar
95th 1200
Blue loctite on all the hardware. My S/E AC even came with a small tube.
Old Apr 27, 2012 | 07:46 PM
simmy711's Avatar
simmy711
Strange, I just pulled my Dealer installed SE Heavy Breather and the crankcase bolts did not have loctite on them?
Old Apr 27, 2012 | 07:56 PM
trekez2's Avatar
trekez2
That's good to hear, I just discovered mine were loose and weeping after about a year without loctite. I reinstalled them with blue loctite.
Old Apr 27, 2012 | 08:26 PM
883_dave's Avatar
883_dave
+1 I use blue too
Old Apr 27, 2012 | 08:27 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Another for the blue. Put that stuff on everything if you're at all concerned. I rarely use it and I always regret it. One day I'll sort myself out...
