Speedometer just died
Old May 6, 2012 | 10:15 PM
kevhed2006's Avatar
kevhed2006
Default Speedometer just died
I was riding my 2002 XL1200c Custom Sportster when I got a block from my house and the speedometer just quit working. Its not a cable speedo its a electronic and I checked the fuses and they were good but there is a big square one with 5 plug ins on it and I dont know if that could be the problem but what was weird the odometer still showed the miles on it but the speedo didnt work and the turn signal would not turn off even when you turned the bike. Could it be a sensor or is it a grounding problem. If anyone could help me I would appreciate it
Old May 7, 2012 | 04:24 AM
IamDiabolical's Avatar
IamDiabolical
most probably the VSS (Vehicle speed sensor) its a common fault. Its located down by the shifter its bolted in the front of the gearbox with 1 allen bolt.
Old May 7, 2012 | 08:12 AM
Gpsjr10's Avatar
Gpsjr10
If the VSS was bad, it wouldn't add mileage. My wife's 02 quit last summer, just got another speedo the other day, gonna try it this week sometime when I get a break between jobs.
I had noticed alot of condensation inside the speedo the last couple years and I think that is the culprit.
Old May 7, 2012 | 10:17 PM
kevhed2006's Avatar
kevhed2006
I have never noticed any condensation in the speedo but I am definitely going to check that VSS. I appreciate the help thank you. Ride on Brother
Old May 7, 2012 | 10:20 PM
Booey424's Avatar
Booey424
I had this happen before. It was the bike angle sensor. Stopped the tach, speedo, and odometer.
Old May 7, 2012 | 11:52 PM
northern64's Avatar
northern64
I had something similar, turned out to be my rear turn signal wires had come out of there spot and got rubbed and were grounding out.
Old May 8, 2012 | 09:51 AM
emperor wurm's Avatar
emperor wurm
i threw my speedo in the trash
Old May 8, 2012 | 12:09 PM
SportyPig's Avatar
SportyPig
Also check to see if the Maxi Fuse has corrosion. I have seen that to cause the Speedo to stop working.
heyhey255
EVO
May 10, 2023 06:10 PM
laz
May 24, 2008 12:13 AM
kensporty 01
May 16, 2008 04:21 PM
Indianspringsaz
Apr 5, 2007 09:40 AM
vicdal
Jun 29, 2006 03:51 PM
