1995, 883 won't start
Old May 7, 2012 | 03:59 PM
Ted Baiamonte's Avatar
Ted Baiamonte
Stage III
Default 1995, 883 won't start
I get a loud clicking sound only. No sign of starter motor or engine turnover. Can anyone tell me what problem is and what I have to do to fix it? Thanks in advance
Old May 7, 2012 | 04:08 PM
reddevil83's Avatar
reddevil83
dead battery?check your connections?
Old May 7, 2012 | 04:13 PM
cHarley's Avatar
cHarley
+1 - dead battery
Old May 7, 2012 | 04:29 PM
slipvayne9278's Avatar
slipvayne9278
i just went through this 2 days ago, ended up being a dead battery, try jumping it from your car, if it turns over, time to get a new battery
Old May 7, 2012 | 11:51 PM
Ted Baiamonte
Stage III
I've had it hooked up to battery charger for 24 hours. Isn't that why I get loud clicking noise? If it won't turn over at all doesn't that mean starter motor or something?? Thanks
Old May 8, 2012 | 06:27 AM
WVHogRider's Avatar
WVHogRider
You are getting clicking noises because the starter is trying to engage but does NOT have enough juice to completely engage & turn the engine over. Do not jump your bike from a car. And if you do, do not have the car running and remove the cables as soon the bike fires unless your feel like replacing fried wires/electrical components. Check the four wire connections with a wrench to make sure they are tight, and you should also have the battery load tested by any auto parts store.
Old May 8, 2012 | 06:54 AM
slipvayne9278
No... I had mine on a charger over night as well and it didn't work, do a load test.. If it goes below 10 volts its no good
Old May 8, 2012 | 08:04 AM
Ted Baiamonte
Stage III
Thanks everyone! I'll get a new battery. Now that I think about I do remember in times past the clicking sound when I first put the battery on the charger, but then apparently it could hold a charge and would start the bike in time.
Old May 10, 2012 | 03:39 PM
jauslong's Avatar
jauslong
Before you go out and buy the new battery, double check your wire connections to and from the battery.
I had this problem on my 883 (and wouldn't you know it happened again a few months later). Thought for sure I just needed a new battery. Someone on this forum suggested checking the wires, and sure enough. Started up like a dream.
deebats
May 27, 2014 09:28 AM
intense883
Feb 22, 2013 05:10 PM
Gremlons
Sep 15, 2011 06:32 PM
VO3434
May 21, 2010 09:41 PM
fixitbychick
Oct 10, 2007 10:04 PM
