Front Wheel sequence
Old May 16, 2012 | 04:07 PM
lzredgt's Avatar
lzredgt
Stage II
Default Front Wheel sequence
My bike is a 2006 Sportster 1200 Custom. While removing the front wheel some of my hardware scattered, and after having a new tire installed I put everything back together. After torquing and reinstalling the brake caliper the wheel turns fine. However I would like to know the proper sequence that the spacers, etc. go in. The H-D manual shows an exploded view for a dual disk, which helped some but not enough to cure my doubts.
My sequence is as follows (moving from the non-caliper side over):
1. Axle and pin
2. Fork
3. shim (?)
4. Hub
5. Spacer
6. Fork
7. Washer
8. Locking nut
9. Nut
Appreciate any help I can get. Lots of good people and info here.
Old May 16, 2012 | 04:09 PM
Scuba10jdl's Avatar
Scuba10jdl
Sounds right. The shim is just a spacer for the other side, although much smaller.
Old May 16, 2012 | 04:21 PM
cHarley's Avatar
cHarley
+1 - Other than sliding the axle in from the correct side, the only thing that can get screwed up is the spacers, and if you get them wrong, the brake rotor won't line up properly with the caliper.
Old May 17, 2012 | 07:27 PM
lzredgt's Avatar
lzredgt
Stage II
Thanks for the help. For some reason it felt like a washer should have went in-between the spacer and hub (caliper side). Maybe I'm wrong, but I think the rear wheel does.
boogyman1313
Nov 14, 2013 10:31 AM
Budds
Wheels/Tires
Apr 26, 2009 05:47 PM
MICHALISLARNACA
Jan 10, 2009 04:47 AM
03RKC
Apr 5, 2007 09:01 PM
tattooedskin
Ironhead
Jul 9, 2006 04:02 PM
