Z bar "need a help"
Old May 31, 2012 | 05:19 PM
IVthCrusade's Avatar
IVthCrusade
Originally Posted by cpracing519
those are 8 " CAPITAL Z Bars, by No school choppers. I have 10" Licks cycles Z bars with 1" risers. The only cable you need to replace is the front brake cable. You can buy a "build your own" kit from Magnum Shielding. 6ft steal braided kit for $55. I cut the line down to about 45" and use 90 degree banjo bolts.
Dude, you're a saint for new guys. Give the same helpful info in every thread asking about 8-10" bars. Thumbs up
Old May 31, 2012 | 07:07 PM
cpracing519's Avatar
cpracing519
thanks, I try to help out as much as I can!
Old May 31, 2012 | 07:17 PM
cpracing519
Originally Posted by Funktup1
Hey CP - Did you need the 1" risers to clear the fork or triple tree? I just got the same bars 10" Zs and plan on putting them on next weekend but I want to make sure they will fit before I take everything apart.
Thanks man!
The bars will fit without the 1" risers, but they will hit the tops of the fork tubes. You can drop the forks a tiny bit to get better clearance or get the 1" or 2" risers from Loner Industries. I had my bars on for a year without the risers and the forks did put small dents in the bottoms of my bars. No biggy though, you will be fine if you don't want risers. I put Joker Machine fork caps on mine so I had to get risers so I could re-mount the bars. The Joker Machine fork caps stuck up to high for the bars to fit.
Old Jun 1, 2012 | 08:02 AM
Funktup1's Avatar
Funktup1
6th Gear
Thanks Cpracing and Pointdogg
Busterjohn
Oct 24, 2014 03:39 PM
06Sporty75
Jun 11, 2014 06:40 AM
The Kid Colaizzi
Jun 4, 2011 08:38 PM
cpotts454
Jul 15, 2010 08:32 AM
scooter34
Nov 25, 2008 07:41 AM
