Shifting
Old May 24, 2012 | 11:49 PM
baka1969's Avatar
baka1969
Originally Posted by DK Custom
Yes, you are correct and I worded my post wrong.
I will putt at 50-55 in 5th, but if I want to do any significant acceleration I will drop it down a gear.
In 5th, because of the "leverage" of the higher gearing, you do not get the same benefit of the torque at 3000 rpm that you do if you are in the lower gears at 3000 rpm.
I might not have explained that well...each gear higher than the previous is like a longer lever working against the torque generated, so the torque that translates into strong acceleration in 1st & 2nd at 2800 rpm is virtually un-felt at 2800 rpm in 5th gear.
Higher gears need to be further up the powerband to give the same (or close) kick in the pants as the lower gears.
Hahaha, I might have butchered that...it is clear in my own mind. lol
Makes sense. I would believe it's because 5th is the tallest gear. But I could be wrong. Right?
Also, I shift at those points under normal acceleration. When I'm running around town I'll shift a little higher or run a little higher. Under hard acceleration I'll shift much higher. Except when I'm in my neighborhood, I try to keep the bike as quiet as possible when I'm on my street. So far I've been respectful and no-one has complained. And I've even asked them. I don't need to be at 4000 on my strret. lol
Old May 25, 2012 | 12:33 AM
Ironman 883's Avatar
Ironman 883
Shifting a Harley is a artform, everyone has a different style.
Old May 25, 2012 | 03:47 AM
Harryinny's Avatar
Harryinny
I went through this with the stealer a week ago. I told them, their recomended shift points and my bikes setup it just dont work. They said, 1-2,20mph. 2nd-3rd, 30mph(in city stay in 3rd while rideing) 3rd-4th 40mph, 4th-5th 50mph. Welp. with the SE Stage1 and the SE slipons, Combined with the higher flow air, its impossible to Stay at 30mph in 3rd, it lugs, spits, hesitates, strdders, ect. so i take it in and wow after the salesman tells me im rideing wrong, calles me noob, and choice other words in emails, I WAS RIGHT. Between 3rd and 4th i need to be higher because on the tessting it showed weakness and sluggishness in 3rd at 30mph big time. The rest of the gears and speeds greatly improved my gas milage also. So the only gears i go higher into the band is 2nd-3rd.
Hated the fact the salesman tells me the price of loking at it depends if i broke something rideing wrong lol. I had a 4 speed for hevens sakes and hes telling me how to run a 5speed? I use to be certified to teach the 3 hour courses back in the late 80's to the late 90's and he was tellong me lol. I called him a few choice names in his office flipped him the bird on the way out and when i came back, threw the repost on my bike on his desk, laughed and walked out. Ya wont see me there again.
Shifting all depends on setup, and what feels right to you. If in doubt, small Tach's arnt expensive and they are easy to install.
Sorry for the long post, i had to share that lol.
Tommy Gilliam
17
Jun 17, 2016 01:09 PM
misput
Nov 4, 2013 07:02 PM
Knights2TheEnd
Sep 2, 2012 02:39 PM
blueangel73
Jun 27, 2011 09:55 AM
rap87
Jul 7, 2006 01:33 PM
