05 1200c starting issue
Old Jun 5, 2012 | 09:46 PM
swofford92's Avatar
swofford92
6th Gear
Default 05 1200c starting issue
Ok, so this morning i went to start up my bike as usual every morning. The engine turned over twice. I heard this loud click then nothing. Nothing but the whine of the starter. The battery is fully charged... all lights are on and working properly. The engine basically wont turn over even though the starter is engaged. I just dont get whats up with it. Any ideas?
Old Jun 6, 2012 | 05:12 AM
cHarley's Avatar
cHarley
A whine from the starter but not turning the motor over, often means a stripped starter clutch gear. Not uncommon on 1200's, especially in warmer climates, typically occurring between 12K and 15K miles.
Old Jun 6, 2012 | 06:34 AM
Gpsjr10's Avatar
Gpsjr10
I would remove the starter and take a look at it. You can also have it bench tested at most auto parts stores.
Old Jun 6, 2012 | 07:58 AM
swofford92's Avatar
swofford92
6th Gear
Well i figured it was the starter, but i figured it was a minute possibility. Ill take ot off and get a look at it. Weve got an account at my shop with all the auto parts sites in town, so i can get them to come pick it up. Ill let you know what i see
Old Jun 6, 2012 | 10:11 AM
cHarley's Avatar
cHarley
If it's a stripped starter clutch gear, your probably going to have to get the part from Harley. The p/n for the starter clutch assembly is 31556-91D.
http://www.surdyke.com/AdvPartInfo.a...mber=31556-91D
Old Jun 6, 2012 | 10:01 PM
swofford92's Avatar
swofford92
6th Gear
I already called harley for pricing, plus my tune up and the gear oil, so i just gotta get it off tommorow. Ill post pictures if i can. Thanks guys.
Old Jun 7, 2012 | 01:17 PM
swofford92's Avatar
swofford92
6th Gear
Update: started taking off the primary cover, but im stuck at a star bolt thats stripped. When i drained the oil, there were ALOT of metal shavings on the magnet in the plug. As soon as i get the cover off ill have pics.
Old Jun 7, 2012 | 01:30 PM
cHarley's Avatar
cHarley
FYI;
If your talking about the derby cover screws, those take a T27 bit which isn't included in most torx sets. If your using a T25 you'll strip the screws.
Old Jun 7, 2012 | 04:34 PM
swofford92's Avatar
swofford92
6th Gear
I am and they already were slightly stripped.... they all came off fine but that one.
Old Jun 7, 2012 | 08:33 PM
Scuba10jdl's Avatar
Scuba10jdl
Drill off the head and you can pop the cover off with the shaft still in the case, then just grab the leftover shaft with vice grips and twist it out.
