Rigid frame starting problems
Old Jun 20, 2012 | 06:30 PM
gunz82887's Avatar
gunz82887
Stage III
Default Rigid frame starting problems
i have a 2002 sportster in a rigid frame. i used the stock wiring harness with some things removed like turn signals and stuff. the other day my battery bracket came lose and pushed 3 wires over and the belt cut them and brought the bike to a stop. i fixed the 3 wires and now it wont start. put a new battery in and tested all the wires i could think of. when i start it, i get 1 spark on each plug and thats it. i tested the plugs, the boots and wires, the ignition module and they all ran fine on another bike. iw as wondering about the tip over sensor or maybe some kind of shut off from the oil since one of the wires cut was the wire that runs to the hook up right under the oil filter. any help would be great.
Old Jun 20, 2012 | 07:20 PM
stlboarder's Avatar
stlboarder
I'd make sure there isn't another short somewhere along those lines. Besides right where they were cut, further up the wire could have been damaged. Did you check the fuses?
Old Jun 21, 2012 | 01:41 PM
gunz82887's Avatar
gunz82887
Stage III
ive checked all the wires with a fluke meter to make sure nothing is grounded, im thinking its some sort of safety device thats keeping the plugs from sparking more than 1 time
Old Jun 21, 2012 | 02:47 PM
Gpsjr10's Avatar
Gpsjr10
The wire to the sensor under your oil filter is your oil pressure light. That would have nothing to do with engine operation. It just simply turnes the light on and off. I would look closely and make sure there are no other wires that you missed.
Old Jun 23, 2012 | 05:54 PM
gunz82887's Avatar
gunz82887
Stage III
roger thanks, what about the my VOES, the 2 wires came out of the back. i was also thinking about the tip over switch, cuz im getting just one spark from each and none of my fuses are blown
Mr.Norm31
Jul 16, 2018 09:31 AM
Danv508
Ironhead
38
Mar 18, 2017 09:30 PM
lonelyrider1966
Oct 26, 2013 11:09 AM
stl jeanes
May 26, 2013 02:56 PM
Bishop73
Dec 14, 2008 05:21 AM
