Stock riser replacement?
Old Jun 26, 2012 | 08:38 AM
Midlife79's Avatar
Midlife79
Default Stock riser replacement?
Anyone know how to tell if replacement risers will match up to the stock clamp bolt pattern on a '12 Nightster? I have the Joker Machine bar clamp that has the same hole pattern as the stock clamp/speedo setup, but I'd like to get some risers that are a little taller than the stock ones.
Old Jun 26, 2012 | 08:41 AM
nc883's Avatar
nc883
I could be wrong here ( it's happened before, my wife would tell ya), but I thought risers came in 2 patterns. Offset, for factory clamps, or straight across.
Old Jun 26, 2012 | 09:31 AM
Harryinny's Avatar
Harryinny
Truen 2 piece risers have 2 clamps and yup they are straight across. Factory ones are offset bolt pattern. There are risers made for this type of pattern, but they are real expensive. Its really easier to get a 2 piece riser set with 2 clamps. Give up the decoration for comfort IMO.
Old Jun 26, 2012 | 10:04 AM
Midlife79's Avatar
Midlife79
I'd like to go that route, except that the Joker clamp I bought was specifically purchased because it retained the dummy lights. If I go to 2 piece risers, i need to figure something to do with the dummy lights. I don't want to ditch them completely yet as I still find myself using them.
Old Jun 26, 2012 | 07:03 PM
HarleyScuba's Avatar
HarleyScuba
You want regular ol' Harley risers. Just like your factory stubby units. There's an offset, where the top two holes are farther apart than the bottom two. These are 8", black, for example:
https://www.denniskirk.com/drag-spec...prd/597144.sku
Old Jun 26, 2012 | 08:06 PM
Midlife79's Avatar
Midlife79
Thanks fellas. Exactly what I was looking for. Now to decide if I keep the Biltwell Friscos I ordered, or put risers on and keep the drag bars. Decisions.....
Old Jun 27, 2012 | 06:15 AM
Harryinny's Avatar
Harryinny
Dont forget, you wil probably need new cables if your bike was made as it is right now. Harley doesnt even give enough room in the cables and breakline to even change stock bars to touring bars let alone risers over 1 inch or more from what ive read and seen. Make sure you check the cables so youll see if your going to hang up with the throttle when turning the bike or if your breakline will take the extra height. Clutch might be a bit forgiving, but not by alot at all.
Old Jun 27, 2012 | 06:33 AM
4zinger's Avatar
4zinger
You probably also want to consider going to Polly bushings while you have it apart. I just put on 4.5 inch pullbacks on my fatboy. Remember lock tight is your friend.
Old Jun 27, 2012 | 06:41 AM
Harryinny's Avatar
Harryinny
Forgot that part. Hey, i went to a dealer for giggles and asked about taking my stock buckhorn style bars off(they dont have enough reach for me) For the mini 12 inch apes with all parts and 2 hrs labor they quoted me $779!!!!! I hate harleys for just the fact they put on just enough cable knowing youll want diff bars some day and they will make a killing on replacements. Someday im going to do the upgrade myself, but i need a seat so i can ride the dang thing. Im making payments on a bike i cant ride LOL.
Axis39
May 16, 2017 07:19 PM
cripple
Dec 6, 2012 06:21 PM
Chad1200
Dec 29, 2009 06:34 PM
09B29
Nov 16, 2009 04:26 PM
Bacon_Grease
Oct 28, 2008 06:50 PM
