DK ignition relocation '03 help
Old Jul 1, 2012 | 01:42 PM
hynfya's Avatar
hynfya
Stage IV
Default DK ignition relocation '03 help
trying to install the dk customs ignition relocation, but can't seem to figure out where the new bracket bolts to. the directions say to bolt to the back top ground bolt of the primary cover, but i can't seem to find that. I'm thinking the directions are for an 04 and up....
Or i'm just completely lost all together on this. can anybody shed some light on where they bolted theirs to on an 03 or below? pictures would be wonderful if possible, since i'm mechanically challenged....
thanks in advance....
Old Jul 1, 2012 | 04:02 PM
USMCDevilDogg's Avatar
USMCDevilDogg
I had the same problem. U have to take the battery completely out to install the bracket. Inside the battery tray theres a rubber support u have to take out on the back side. Take out the rubber support and bolt the bracket to the hole. It's a tight fit but it works....Hope this helps.
Old Jul 1, 2012 | 04:18 PM
hynfya's Avatar
hynfya
Stage IV
usmc... thanks, that helps 1000%. picture is perfect as well... makes more sense now......
ill let you know how it goes later tonight when I get to it.....
Old Jul 2, 2012 | 03:33 AM
hynfya's Avatar
hynfya
Stage IV
thanks for the help usmc, took me awhile, but finally figured out that it had to go through that slit in the battery cover. fits good, everything attached and working.
do you have any problems with the heat generated from the pistons on your keys?
Old Jul 2, 2012 | 06:35 AM
USMCDevilDogg
Glad you were able to figure it out. No, I havent't had any problems with the new location.
HolyHandGrenade
Electrical/Lighting/Alarm
Dec 22, 2014 09:17 PM
DaveNBPT
Feb 23, 2013 05:41 PM
pleasants9
Apr 10, 2012 02:38 PM
Deepsouth251
May 16, 2009 04:24 PM
EVO80
Feb 25, 2008 05:54 PM
