Carb leaking, stumped
Old Aug 7, 2012 | 05:32 PM
Nilla's Avatar
Nilla
Default Carb leaking, stumped
I'm working on a friend's sportster. The carb has been leaking fuel.
It's a a 1990 CV carb, on a 1996 XL1200. I'm basing this off the fact that it has the two circular floats used in 88-90 instead of the common U shaped float. Local dealer confirmed this via parts manual. He bought it used a couple months ago.
The floats are intact, and when tested do float. I replaced the float needle, no change. The floats are adjusted properly to HD factory specs. The drain screw o ring is good, the bowl will hold fuel and not leak from there when testing. Accelator pump o ring is new. The jets are clean, the bike runs great aside from this issue.
I just dissasembled the entire carb, and I think the diaphram may be degrading. There was a thin layer of black sooty-looking stuff all over the inside of the carb, even in the upper end. It was everywhere. Not brown, gummy carb looking crap, it was jet black and a very fine layer. I've never seen a carb dirty like this on the upper end. The bowl was clean.
What am I missing? I'm assuming at this point that a vent passageway somewhere is clogged.
-- The petcock does leak slightly, and I'm going to rebuild it, but regardless - the float needle should still stop the flow of fuel.
I'm stumped.
Old Aug 7, 2012 | 06:32 PM
John Harper's Avatar
John Harper
I left my petcock on one time, and it opened the float needle valve, could have been related to a full tank of gas. Except for that, it never leaks. I'd just rebuid the whole enchilada and get a fresh take. Fix the petcock leak too.
John
Old Aug 7, 2012 | 06:41 PM
waynerds74's Avatar
waynerds74
If you've installed your bars and adjusted your throttle cables, I've found that if your idle cable is too tight, it will cause fuel to leak/pour out of your carb.
Old Aug 8, 2012 | 06:42 AM
Nilla's Avatar
Nilla
Not the cables, it'll do it when only the fuel hose is attatched to the carb for testing. I have found that the float height setting on this thing is crazy sensistive.
At 15 degrees, like the manual specifies, I had it set to .710. Fuel was pouring out. I set it to .730, and it was so starved the accel pump would only get one good suirt before it starved.
It's a .720 now, and the leak is still there, but it's very slow. I'm wondering if ethanol in the fuel has degraded the floats and now they're not acting right?
Reed's 1200
Mar 23, 2019 01:53 PM
Maughanaj
Sep 23, 2017 01:30 PM
All Aces
EVO
30
Jul 27, 2014 07:42 PM
ardvark
Shovelhead
May 24, 2008 12:40 PM
jprcr4
Exhaust System Topics
Oct 23, 2006 01:19 AM
